OT: Wind damaged shingles--glue?
Results 1 to 9 of 9
    Sep 2006
    Dickson, TN
    1,719
    45
    74
    Default OT: Wind damaged shingles--glue?
    Same elderly lady that needed her concrete pressure washed has some (8 or 9) asphalt shingles on her roof that were damaged by a recent storm. I looked at them today and her "damage" is minor with the shingles lose where they were glued -- I think they were glued -- to the shingle underneath. What is the best glue to use to get these shingles restuck? She is worried here roof will leak but I do not think it will--even if nothing is done.
    Or do you have a better suggestion? Thanks
    Apr 2002
    Syracuse, NY USA
    9,588
    16
    538
    how about and insurance claim for wind damage? she could get part or all of a new roof. othewise, the exterior silicones work well on roofing.
    Apr 2007
    mays landing NJ
    438
    400
    112
    Are the shingles torn or just not glued down tight? If they are torn I would replace them.You need to cut the nails off or possibly pop them up. There is a flat bar made for this. If they are not torn ,you can apply flashing cement from either a caulk tube or from a can.The caulk tube is not as messy.Apply three dabs the size of a nickel and about
    1/4" high 1" up from the bottom.This is for each tab ,usually have three tabs per shingle.
    mike
    Jan 2002
    West Coast, USA
    7,251
    353
    4195
    Roofing cement - a black asphalt-like product - is what's meant for this job. Many other glues may either not stick well (some silicones) or damange the base (glues with higher solvents).
    Available in caulk cartridges or cans.
    Feb 2006
    Oakland, California, USA
    1,780
    17
    13
    Home Depot sells "Henry's" brand roofing tar in a standard-sized caulking gun tube. Just what the doctor ordered for this kind of fix.
    Apr 2008
    Rapid City S.D. USA
    211
    the roofing glues and tars from black jack are good stuff and meant for the pourpose you are asking about.
    Oct 2007
    Howell Mi
    2,226
    11
    Thumbs up Another vote for roof tar.
    I like the stuff in a can, and apply with a putty knife. Clean up with gasoline, and call it good. For a temporary fix on torn shingles, take a piece of tar paper, and cover it with a thin coat of roof tar. Stick it to the back of the shingle so the tear stays together. It helps if you put a bit of tar in the tear in the shingle. Then put a dab on the bottom of the tar paper, and stick it to the shingle below. Had this type of repair hold up for years, but it can fail if an ice dam or heavy snow melts then freezes again on it. Works better on steeper pitches. Just don't step on it.
    Aug 2005
    Tacoma Washington
    1,338
    85
    124
    The roof cements work great, but remember that this is a temporary fix. Eventually they will need to be replaced.
    Mar 2008
    Vermont
    1,207
    75
    What Junkyard J said. Your repairs will outlast the rest of the roof.
