Bruce Griffing
Titanium
- Jan 1, 2003
- Temple, Texas
I have several PC that run Windows XP. Because I wanted to add an SSD, I decided to upgrade some of them to Windows 7. It turns out that you can buy a 3 machine upgrade (Home Premium) for just over $100. It contains both 32 and 64 bit versions - your choice which to use on each machine you upgrade. The upgrade from XP is really a clean install - which did not bother me since I like to clean the system every so often anyway. The surprise was that at no point in the process was I asked for my XP code. It appears that I could have done the install without having a previous version of Windows. I did the upgrade onto a new hard drive. It failed the first time - I think because I made a typo when putting the W7 code. But it could have been because there was no existing WXP installation on the machine. It worked fine the second time, so I suspect the typo theory is correct. FYI if you want to upgrade a few machines.
