Results 1 to 7 of 7
    Spud's Avatar
    Spud is offline Titanium
    Jan 2006
    Brookfield, Wisconsin
    2,334
    Default OT: Wood refinishing questions.
    Wood windows and doors , aprox. 5 years old. Old varnish and or stain needs to be removed.
    Of the following 4 choices , which works best in removing the old finish:
    Kerosene, Thinner, Turpentine or Paint remover?
    Once I have got down to bare wood, what do I apply first: Water repellent/sealer or varnish or stain?
    69BBNova is offline Plastic
    Jun 2012
    USA-Rhode Island
    8
    I dont have an answer but lumberjocks.com has all the info you need...
    I'm a member there and also overclock.net...
    Their all the parts of my obsessions, including here.
    peterve's Avatar
    peterve is offline Titanium
    Jan 2005
    The Netherlands
    2,973
    Heatgun and scraper
    Enjoy
    Peter from Holland
    henrya is offline Hot Rolled
    Jun 2008
    TN
    851
    What do you want them to look like when you're done?
    Stain? Paint? Other??
    lowCountryCamo's Avatar
    lowCountryCamo is offline Cast Iron
    Jan 2012
    Savannah, Georgia, USA
    318
    Heat gun or acetone should work. Paint stripper will also work but it is nasty. Cabots brand at lowes sells a good quality exterior stain. Get to the tone you like and then varnish or poly. I would look for an exterior varnish though.
    Screwmachine is online now Stainless
    Mar 2001
    Switzerland
    1,638
    Jesus- I would find out whatever was done to them in the first place, and do the opposite of that. 5 years is way too short to have to do a full strip/refinish.
    Apr 2006
    Birmingham, Al.
    147
    I used to work for a furniture refinisher. If the finish is actually varnish and not some new urethane, the ketones will cut it fine (acetone, MEK, etc.). Use an organic vapor respirator. If it is a marine type, poly, or isocyanate then a product called "Peel-Away" works great. It is rather expensive, but it is safe and easy to apply. You'd want Peel Away 7 which can handle newer harder finishes. It's about 120.00 per gallon. I stripped the woodwork of a bungalow which is used as a museum here in Birmingham for a poet named Samuel Ullman. Some of the woodwork had literally 25-30 coats of paint. Peel Away handled it fantastically.
    Michael
