They also dont get limits and fits and components vary wildly, you have little chance swaping bits from one machine with another they either wont go or flop around.
the japanese dont seem to suffer the same problems, neither do the koreans.
i suppose we in the west will be well screwed [lol]when they do get the idea.
regards
mark
The chinese DO "get" limits VERY well. A set of folks generally more oriented towards meeting the specifications you will very seldom find.
There are a few problems.............
First, they do NOT have a very long manufacturing history, as far as modern times and products. Cast iron may go back 3000 years, but proper composition etc may be only 40 years at most. So what you expect "anyone" would know, do, etc, they have no clue about.
Second...ANYTHING meeting spec will be shipped. Usually this will be by "inspecting-in" the quality, checking 100%, starting from a rather wide "universe" of parts, a very substantial part of which do NOT meet spec.
That means there will often be "leakers". You may get a shipment where there is a half bell curve, ending at the lower or upper limit, and a proportion of "leakers" outside the limits.
The lesson is NEVER to expect a bell curve. Your limits had better be set so that any combination of limit values will still work OK.
Third.....Anything NOT specified clearly is usually interpreted as being open for any changes. This can cause "surprises".
Fourth..... The sample is the law. Each sample is a new item, and you must check every single part of it. if part "b" was the only thing not perfect on sample #1, then on sample number 2 you may THINK you can check just part "b" only.....
That is NOT SO. Sample #2 is a complete new item, and may have a number of changes in items which you didn't specify so tightly that there cannot be a change. Even maybe if there was a spec, SOME contract manufacturers will substitute "something close" if the actual item is not available, or if they think the right one is too expensive. They may not have the same idea of "close" as you do.
The latter type of manufacturer may make that sort of substitution in the middle of production, well AFTER a good sample is approved. Normally you find out only after your letter of credit has been released, so your leverage is reduced to refusing to buy from them again.
It is 100% "buyer beware". As costs continue to squeeze the chinese, expect that to INCREASE, not get better as you'd expect.
