Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Like Tree6Likes
Thread: Pallet straddling engine hoist?
  1. #21
    gkbikers is online now Aluminum
    Mar 2012
    Buford, GA, USA
    79
    Quote Originally Posted by sa100 View Post
    Pallet jacks are a cure for world hunger. For fifty bucks you can easily and safely move two and a half tons. Everybody should have at least one!
    Steve
    How about a 6500 lb machine? I have a "new to me" Kearney & Trecker plain horizontal 2K sitting on a heavy duty, custom made pallet. After I bought the mill, I realized that most pallet jacks will not lift it. So now, I'm looking at investing in a 6600# pallet jack from Global.
    Do you think it's worth $300 to make that purchase?
    gkbikers
  2. #22
    KMoffett is offline Aluminum
    Aug 2010
    Minnesota USA
    100
    Yes! Buy it...use it...sell it. It will cost you less (maybe half) than $300.
    Ken
  3. #23
    surplusjohn is offline Diamond
    Apr 2002
    Syracuse, NY USA
    8,850
    what you really need is a gantry. you could even bolt together a decent one. or look around for a stradle lift, these can be gotten cheap at auctions, can be electric or manual. tend to be 1500 lb capacity, but some are higher. I had one that was probably rated at 1500 but used it several times to pick up machines that weighed 2500 lbs where I could not get a fork lift in. for instance the second floor of a building with a small elevator.
    These go cheap, because people truely hate them.
  4. #24
    tailstock's Avatar
    tailstock is offline Cast Iron
    Apr 2009
    Ontario Canada
    438
    Use to fight with lifts and gantries and finally got smart and bought a decent fork lift. Now I can move skids as well as unload whatever is on them. Life is too short, work smart.
    Ray Behner and nalambright like this.
  5. #25
    jamesrransom is offline Plastic
    Idaho
    if you would look at american engine hoist on facebook , it might help, has built in leveling system , counter balanced, legs are not under load, can lift 1 ton from the end of the boom or hydrolics on the mast
  6. #26
    gary s moore is offline Plastic
    Nov 2008
    Rock Island Wa USA
    21
    I had the same trouble loading heavy shaft on lathe.
    Take lift system off base turn 180 degrees remount and counterweight on former front legs.
    Now you have free aria under load and can position up to lathe , mill , or pallet.
  7. #27
    Milacron's Avatar
    Milacron is offline Diamond
    Dec 2000
    Coastal Dogpatch, SC, USA
    41,119
    Quote Originally Posted by gkbikers View Post
    Multiton makes a 10,000 lb manual pallet jack... I have two of them. Trouble is, after about 6,000 lbs you can't actually get the thing rolling unless your floor is perfect. Also, after about 6K they are a bitch to lower smoothy. Better is my Clark 6,500 lb electric pallet jack, which will actually lift about 7,200 lbs and rolls easily under power. Also, even maxed out, it lowers smoothly with the press of a button. The electric ones in that capacity are just made way heavier duty all over as well....you can lift things with one leg without the jack tilting or bending. Place to buy them is at live auctions...paid $30 each for mine (yes, $30..with usable batteries too ! )...I have three !
    But sounds like the OP wants to get a machine off a pallet...in which case a pallet jack is useless. And a Johnson bar is useless as well once you get over about 1,000 lbs and if the pallet is projecting out further than the machine base. So he either needs to straddle the pallet or use a forklift to lift with straps from above...or if really desperate, use electric saw to cut the pallet out around the base and use toe jack(s) and blocks to lift it above pallet and slide pallet out...then lower on 4 x 4's. From there you can easily get machine to floor, but that's another story.
  8. #28
    Clive Hugh is offline Aluminum
    May 2007
    Western Australia
    161
    I just recently went thru a similar thing when I bought a new lathe and mill. I made a lift out of 3" squ. hollow section. Just looks like an upside down "U" . the top beam sits on the legs so the load is compressive. I put removable feet/supports on the bottom. Used a chain lift to raise the machines, pulled out the pallets, lowered onto a pallet trolley and moved them to where I wanted, lifted them off with the chain lift and lowered them. Simple as that.
    You say you are not a good welder, as long as the load is compressive and not in shear you don't have to be coded. if you can get someone who is competent to weld it. As far as splaying under load goes you can rig up a chain between the legs to prevent that. I am going to turn my lift into a dual purpose lift/ press on my next project. When not in use the feet come off and it stores flat against the wall
  9. #29
    cegreen is offline Aluminum
    Feb 2009
    New Jersey, USA
    200
    Hi Clive - sounds interesting. Do you have a picture by any chance?
  10. #30
    traditional-tools is offline Stainless
    Aug 2007
    San Jose, CA
    1,774
    Quote Originally Posted by metalmagpie View Post
    Not much to look at!
    Attachment 49945
    I see you have a gantry in the back there...that would come in handy for getting a pallet out from under a machine.
    Quote Originally Posted by surplusjohn View Post
    I agree, it is one of the few safe ways to do that.. Me and a friend constructed our own gantry for a 2000 lb. machine, to lift out of a pickup, then drove the pickup out from under it and lowered it to the ground. This might be doable for a 6500 lb. machine, but I'm not sure I would trust that much weight on wood, better to have metal, and especially a specific gantry designed for that much weight.
    The safest solution is to use a forklift with straps from above, or a crane. If you have the space a gantry might be the cheapest solution if you need to purchase something. You'll also need a chainfall for that as well...custom pallet could be your cheapest option, but ONLY if the machine will fit between the legs to be able to lower it to the ground. 6500 lbs. is heavy, if you tip it over, something will break and you won't be happy and someone could easily get hurt, so think it through before you make a final decision.
    Milacron makes a good point, a pallet jack will do you no good whatsoever to get the pallet out from underneath, nor will a johnson bar. So unless you can get the machine to your shop from trailer on skates or pipes, a johnson bar will be useless, IMO. 8000 lb. forklift would be my choice with slings from above. The straps I use to lift logs will handle a load like that 6000 single point or 12000 lbs. as a basket sling, but they cost about $50/pair for 20' slings. You don't have a lot of options, think it out thouroughly before doing something stupid...my $0.02...because even if you could modify a engine hoist to allow the machine to fit between the legs, few will lift 6500 lbs.
    I found a pic of using a basket sling, it requires both ends be secure from above.
  11. #31
    WHHJR is offline Hot Rolled
    Jun 2009
    Near:Louisville, KY
    763
    It all really comes down to; do you want to be in the rigging business or not. A forklift is just about the best bang for your buck (if you buy it right). I bought a 5000 lb Yale 10 years ago and use it at least once a week. It is just too easy to use. My shop is overloaded with Stuff so I move Stuff regularly when a different space requirement comes along.
  12. #32
    May 2007
    Western Australia
    161
    cegreen, no I don't but I will take a couple of shots tomorrow morning and post them - or try to post them, I haven't posted photos for a while.
    Clive
  13. #33
    May 2007
    Western Australia
    161
    cegreen, I tried to upload the pictures but it crapped out. I think it would be quicker if I paddled a canoe to the US from Aus and hand delivered them. If you send me an email I can attach them to that.
    Clive
  14. #34
    Feb 2009
    New Jersey, USA
    200
    Default Pictures of Clive's Lifting Frame
    Clive was nice enough to take the time to shoot some pix of his lifting frame and make a sketch. Since he had trouble uploading them, I'm doing it. -Chris
    The legs bolted on. All bolts are 12mm – you’ll have to use the nearest imperial equivalent, in this case 1/2 inch.
    When assembling I just put in the central bolt on each side, lift and put in the brace bolts, it’s really easy. Once you get the first brace in it all is self supporting so you can get them all in and tightened – leave them loose till you get them in.
    This shot shows the slot in the bottom so the hook can go up inside – this gives a bit of extra lift and I can bolt on a jack for a press without any lugs getting in the way.
    I have dimensioned in metric as I always use it for fabrication, it’s much easier.
    Note with the slot in the top – the pin hole is off centre so that the hook clears the top. I used a 16mm (5/8 inch) bit of black mild rod and drilled 16mm dia for it. As the dia on black mild is slightly under it is a good fit with a few thou’ clearance.
    The 12mm bolts were given normal clearance for 1/2 inch. either 14mm or 9/16
    65mm x 65mm x 3mm tubing approximates 2.5”x 2.5” x 1/8”
    40mm x 40mm x 6mm tubing is 1.5” x 1.5” x ¼”
    40mm x 6mm flat is 1.5” x ¼”
    You’ll see that the support leg clears the ground when the bottom foot/leg is bolted on. this is to allow the whole foot to be in contact with the ground.
    I have only lifted 595 kilos with it. As reassurance, assume that the pin is in double shear and (.3125 x .3125 x 3.142 x 26 tons per squ.inch) x 2 for double shear= 15.95 tons. So it’s plenty strong enough.
    Same with the welds: 1/4 leg = .25 x .707(tan 45o) x length weld (10 inch all round per leg) x 70,000lbs tensile / 2240lbs gives a figure of 55 tons. Admittedly this is cross shear but it’s still plenty strong enough for general purpose lifts. Which explains why even a crappy weld can give so much grief when you try to break it.
    -Clive
  15. #35
    May 2007
    Western Australia
    161
    Thanks Chris.
    Clive
  16. #36
    Ron of Va is online now Aluminum
    Jul 2008
    Tidewater, Va
    177
    I think that hoist needs some anti-racking supports at the top.
    mister honey likes this.
  17. #37
    Doozer's Avatar
    Doozer is offline Stainless
    Jul 2001
    Buffalo NY
    1,383
    Commenting on the Blue gantry,
    By milling out the middle of the cross beam (tubing) you took away lots of strength, like half.
    The bottom of the tubing will be loaded in tension, and you cut 50% out of the main tension member.
    Not good.
    -Doozer
  18. #38
    May 2007
    Western Australia
    161
    I only made it to lift my lathe which is 595 kilos, no problem at all.
    Clive
  19. #39
    Doozer's Avatar
    Jul 2001
    Buffalo NY
    1,383
    You did some math on the weld strength,
    but if all the force is straight down, welds
    will not even see any stress.
    (actually a good scenario in this case).
    You did some math on the load pin
    in double shear, but it is not in tight
    double shear, it is in shear over the
    width of the tubing, so maybe a
    bending moment calculation would
    be more appropriate.
    You ignore the big cut out which
    I mentioned, and say it only has
    to lift so much weight.
    Typically it is best to identify the
    weakest point and run a calculation
    on it. The stronger stuff is less of
    a concern.
    Just trying to keep it safe.
    --Doozer
  20. #40
    May 2007
    Western Australia
    161
    Doozer, I calculated the welds as a reference, I realized it is in compression, there is/was a chance that it could splay and that's why I wanted to know the strength. As it happened there was no splay, even so I had wrapped a chain round it.
    I knew the pin would support the load as I have used a similar thing in the past. And the same goes for the cutout. I agree with your comments about making it safe.
    Clive
