Richard Rogers
Titanium
- Nov 27, 2001
- Bentley, Louisiana
I've, of course, used teflon tape for years on air or water fittings. I've used it on hydraulic stuff, and I understand that can be frowned upon, because it could end up clogging something, etc, in the hydraulic system, so I don't do it much. I've used the "pipe dope" stuff, and by using that term, I'm lotting many brands of "stuff from a tube or brush-on can" that you put onto pipe threads to seal them.
I was very pleased last year with a product from LocTite that I stopped a leaking fitting in an Allison forklift transmission by using. Only problem was it was not cheap, but still worth the expense for this hard-to-reach fitting.
What do you find works in what instances? What brands and products do well for you? What has let you down? What has pleasantly surprised you? What stuff has a good or poor shelf-life?
As a "by the way" thing--How many times can NPTF fittings be removed/retightened and retain their "better than just NPT" qualities?
I guess I'm just on the subject of leaks and preventing them because my Pop was fixing air leaks all over the shop today, and leaks are a problem I'm sure has nagged us all.
Richard
Richard
