mrtoes
- Mar 15, 2014
- Amherst, NH
I have an old Mori Seiki SL-BB that had a brain aneurysm ultimately resulting in controller death. I am in the process of retrofitting a new PC based control to the machine. I need a secondary controller to operate components such as tool changer and hydraulic systems, was planning to use a plc for this application. The problem i have encountered is my own lack of understanding when it comes to basic electronics/automation systems. I bought an AB micrologix 1400 off ebay and later found that i would need to spend $2000+ for the software to program such device (not in this lifetime). I am hopelessly retarded when it comes this type of work. If i may, i would like to draw upon your (the viewer's) experience to locate the proper equipment for this job. I need something easy enough for a rhesus monkey to program (preferably something that can be programmed with open source software or at the controller via a softkey pad). I need approximately 35 inputs with 10-14 outputs. Price is also a factor. Would like something in the $100-300 range (used is fine, im dirt poor).
Thank you for your time
