lincoln
- Jan 2, 2008
- san jose, ca, usa
Hello
I have a part that is is effectively a shim plate, we are holding it in a customer provides vacuum chuck. The part is 14" in x by 4 in in y. it is cut out of an 1/8" plate that gets cut down to 0.110 basically the problem is that since we are cutting on one side the plate bows once the vacuum is turned off.
cutting both sides in not an attractive option because getting the parts to seal again is not an easy thing.
The material provided by the customer is 6061-t6 while the print calls for 2024-t4. In the function of the part the lower strength of 6061 is not an issue.
the thickness is consistent so i don't think it will be a problem but i haven't heard back form the customer.
so my question is: do you think that 2024 tend to bow less than the 6061?
what else do you think? we could cut both sides .....
thank you for your time, link
