porous material?
Results 1 to 15 of 15
    Jan 2004
    Fulton, IL
    859
    5
    Default porous material?
    Anyone know of a material that is machinable, won't corrode in water and is porous enough to suck water and air through it?
    Feb 2008
    Oak Lawn, Illinois USA
    11
    Try sintered stainless steel. Does it have to support a lot of weight or be a strong part of a structure? http://www.smallparts.com/products/descriptions/pxx.cfm
    Butch
    Jan 2004
    Fulton, IL
    859
    5
    Large molds will be made out of the material so it has to be economical. It doesn't support much weight.
    Feb 2004
    peekskill, NY
    23,695
    3881
    Bronze sinter.
    Jim
    Apr 2006
    Suffolk, England
    841
    69
    204
    Have you thought about using Porcerax?
    http://www.porcerax.com/
    Peter
    Jan 2004
    Fulton, IL
    859
    5
    If I could find a tough plastic that had different micron filtrations to try in say a 4" x 24" X 24" piece, that might work.
    Jan 2004
    Fulton, IL
    859
    5
    I will look at porcerax.
    Apr 2002
    Syracuse, NY USA
    9,587
    16
    537
    there are lots of foams that are machinable and are open for water, also there is a foam glass that is normally closed cell but is available reticulated, also know as fart rock, used as a fire proof insulation. depends on what you are doing.http://www.crestfoam.com/bull101new.html
    Sep 2004
    El Dorado, Ar. USA
    62
    Default Porous Materials:
    A number of refractory materials are porous and, at least to some extent, machinable. Contact some of the industrial refractory supply companies (or installers) in your area. You will find more of them than you think. Probably can get samples. Both insulating firebrick and castables come to mind. We (employer) used to use them before I retired.
    A number of metals are available in sintered form and with varying porosities.
    If we knew your application we could better recommend something.
    The pottery industry uses plaster of Paris as molds to suck the water from casting slip - everything from toilets to pots.
    Sep 2004
    Oakville, ONT, Canada
    337
    I would suggest nickel foam, but I'm not sure what the retail price would be, how large are these molds going to be? On the other hand, there are some refractories as mentioned, we use a type of alumina that comes in various porosities, from vesuvius, it is used widely as a filter in casting operations, so it is disposable. It is easily machined too.
  11. #11
    Jan 2004
    Fulton, IL
    859
    5
    The molds could be 8" X 24" X 24" larger or smaller. They sit in water so aluminum corrodes fast. Currently using a plastic but not porous. It has to have a bunch of holes drill in it which isn't practical.
  12. #12
    Jul 2005
    Chevy Chase, MD
    1,057
    76
    86
    Back in my lab instrumentation days I made a few things from porous PTFE. Expensive and a little difficult to work with.
    http://www.microporeplastics.com/porous.htm
    Maybe some useful info?
  13. #13
    Aug 2006
    Brisbane, Queensland
    1,288
    Is there more information on the sheets of sintered bronze. A website maybe?
    I have a couple of sheets which I suspect is this material and would like to know how it might be utilised.
  14. #14
    Apr 2002
    Syracuse, NY USA
    9,587
    16
    537
    I recall seeing an artical about using a cast material, possibly an aluminum epoxy mix for making vacuum forming molds.
  15. #15
    Aug 2001
    Batavia, IL USA
    1,922
    52
    57
    How about porous plastic, like one of the polyethylenes (LDPE, HDPE, or UHMW)? We fabricate something similar at work for propietary R&D projects, but there are probably fabricators out there that can make something for you. Machinability might be a problem, especially for the lighter grades of PE.
    Mike
