Corry
- Feb 21, 2011
- Fairfax, VA
Most posts I see on this devolve into phase converting, and I really wish that was an option here! Otherwise it seems to be for larger multiple machines at once kind of shops. So yes, my use case is rare.
I bought my house because 3 phase lines are a few feet from my property (like 6 feet). I figured there was no way 3 phase power could cost a lot to put in. Boy was I wrong! Rocky Mountain Power quoted me "tens of thousands" for three phase, then then recommended larger single phase service. So they offer 400A at $10k, and 600A at $14k! That's not getting the panel upgraded, or wires to the shop. That's for them to run a cable 50' in the air, or run a cable 50' in the air and install a current transformer. (Oh, and the part they didn't say, but then they'd want to charge me commercial power rates). I don't plan on being any sort of job shop so that's ridiculous. If I was, I'd get a commercial property! (and pay commercial rates!)
Ok, so power company rant over, if I want to power a machine, I'll have to generate the electricity. It sucks, but I also bought enough land that a generator in a decent enclosure should be ok for noise levels.
I guess I'm mainly looking for people's experiences with generator sizing, surge capacity, etc. One machine makes this quite possibly the worst case scenario. I've heard double or triple the motor power used to set the generator's "operating", not surge capacity, rating. This confuses me a bit, because the surge capacity is what I'd think should be looked at. Then again, I don't want a generator that stalls trying to start the machine. I called the local haas dealer and they said one step up (like a 30KW instead of a 25 for a 30HP/22.7KW machine) is probably all that's needed, and that its easy to pull the computer off the generator and onto landline power (though I can't help but wonder about ground issues with that thinking about it a little more).
Anyhow, I'm looking to see if anyone out there has run a single machine at a time from a generator and what they found their sizing needs to be. I don't want to waste fuel with a large displacement generator running at 0.1% of its rating, but don't want to stall out either! Further, I'd like to run the generator from my natural gas line if possible, but there's no way I'm fueling a 60KW generator from the house lines! If that's a firm requirement, I'll have to go with a propane tank! (I'm not even sure if it would be quiet enough to run without a noise issue!
