I need to make a coupling for a fancy servo. It would be a cylinder aprox 35mm long drilled 8mm from one end and 10mm from the other. The two holes need to be round and concentric within 5 micrometers. Any suggestions will be warmly appreciated.
I'd be interested in how the 5 micron cylindricity spec for any one hole alone, gets done anyway....
You did not say what the OD is, if it is in the range that could be held with an accuracy 5c collet, I would bore and turn the finish pass consecutively so that both are concentric. Turn it around and fuss with a tenth (2 micron indicator) till you have it as good as you can, bore the second side.
You will not be able to do any better with the equipment mortals have, how is the end user going to prove it is not correct.
I have a fixture I routinely have set up. I can get it to indicate zero by fussing with it, I have a mark on the fixture that I line up with the 5C mark then rotate it back and forth from there till I get zero. the next time that is not good enough putting a little pressure on the fixture as I close the collet does the trick. Ten years after making it I can still get it to work be hook or crook.
...Buy the hole first from a specialist as a hard-vacuum...
Had to go back and read that one a second time...
Could I poke my nose in here and confirm that you're looking for two coaxial bores of 8mm and 10mm diameter, not depths as I think some have interpreted your post? If so, then a single setup where you bore the 10mm, then the 8mm further in, will get your tolerance done as long as the lathe has good headstock bearings and decent ways near the spindle.
The point raised of what happens during the clamping itself is a good one, and should be addressed. Sometimes a circumferential clamp geometry can be incorporated into the coupling, if you do that with yours by roughing-in the bores to ~.1mm undersize, tighten the clamp screws a modest amount to preload the system, then finish bore for size and concentricity you can achieve a very good clamped axial accuracy.
Bore both diameters,10mm dia. to leave the 8mm dia. to length and then put a 10mm bung in to leave 10mm dia.to length.
Tolerances etc.not my problem but I know of a world class inspector if you need one.
"Actually, given the general size of the coupling 5 microns is not that tight."
What temperature do you want them to be within 5 microns?
Reminde me, was that 5 microns TIR or +/- 5 microns?
Well if they are through holes just bore them,much easier than any other way.
Oh we all have to do that with all of his posts.
Be kind to the elderly, some day it will be you and me writing this stuff. I'm getting closer
Notice
