The Winch
- May 25, 2010
- Seattle, WA
Hello.
I need some ideas regarding a winch.
I am remodeling a house at the bottom of a fairly steeply sloped 5 foot wide gravel walkway. We are not able to drive to the house. The walkway is 150’ long.
I want to be able to haul construction debris up and take construction supplies down. My best idea is to have a cart that is tied to a cable and winch the cart up the hill.
Here are my questions.
The winches I see only move about 10 feet a minute, so that means it would take 15 minutes to get the cart up the hill. That would not be practical. Are there significantly faster winches?
I figure I will be hauling about 500-800 pounds in each load. I see some winches with 100 feet of cable, do they make them or can I swap out the cable to 150’ in length?
I have access to AC power at the top of the walkway. Would an AC or DC winch be best?
Do you have any other ideas, other than a winch, to get the cart up and down? I am also considering using a system of pulleys and pulling the cart up with my truck which would be at the top.
Thanks for your help!
Dave
Dave
