Propane Tank Laws?
Results 1 to 17 of 17
    Aug 2004
    Ohio, USA
    2,072
    303
    98
    Default Propane Tank Laws?
    I have a down right cute little propane bottle that looks just like a little mini oxygen/acetylene tank. I took it to my welding gas supplier today to have them look at it...they were impressed with it, but sadly said they couldn't legally fill it. They said it needs to have a OPD valve on it...and the small dents it has are not a good thing...they refered me to another welding supplier, and they told me that unless it has a date on it (which the first supplier couldn't find on it) its junk.
    So I'm curious, does anyone know how the laws work with filling propane cylinders? Is there a national standard or does it vary by state? From what I've been able to find out, up to 40 pound tanks gotta have the OPD valve on them. I can't seem to find out for sure if industrial cylinders are exempt from the OPD requirement. The first supplier said they aren't.
    Thanks!
    Eric
    Sep 2008
    Anytown, USA
    334
    47
    38
    IME, to fill a tank, it doesn't have to have an OPD valve on it (finnicky things too).
    If your tank currently has a POL though, then no one will legally fill it. Sounds to me like you just need a new valve, but not necessarily an OPD.
    Sep 2006
    SE PA, Philly
    5,087
    907
    1569
    NFPA Pamphlet 58 (1998) requires that all propane tanks from 4 to 40 pounds have an Overfill Prevention Device (OPD). Most states have adopted the 1998 standard (or a more up to date version) as law, and hence, filling a tank without such a device is not legal.
    There are some exceptions to the requirement (tanks for industrial cutting and welding gases, tanks for industrial trucks, some horizontal tanks...) but in general, your propane tank needs an OPD.
    Gee, I feel like Hank Hill.
    Jim
    Aug 2008
    Murfreesboro, TN. USA
    694
    133
    Federal law has changed, I have 6 propane thanks that are now all worthless. It is cheaper to buy new tanks than to replace the valve and have them tested.
    I like to have several tanks of propane it is good to have a spare. I bought a new tank turned it upside down set it 4 ft above the old tank and connected them both together with a flexable hose. Turned on both valves and in a few days the new tank will gravity feed into the old tank. Then get the new tank refilled and 1 by 1 I can fill all of my old tanks.
    Nov 2004
    Webster Groves, MO
    6,078
    1441
    2377
    Yep, I had to replace my tanks. Re transfilling, putting one tank outdoors and the other indoors, the feed one in the higher temperature and the receiver in the lower, speeds up the process. Putting the feeder in the sun helps. Of course, being totally law abiding, I scrapped my old ones. And if you believe that, I have some Brazilian brass mine stock I would like to offer you, only selling because the economy is down, etc.
    Bill
    Oct 2008
    Berlin Center (NE) Ohio
    1,888
    20
    Eric;
    Some of the shops here will fill them for welding (industrial) use. Not sure why. I also sent you a PM.
    Craig Donges
    Nov 2005
    N E Florida
    1,996
    168
    Around here the convenience stores have a 20# tank pay and swap system. I took my old tanks there and swapped them! The gas costs a few dollars more but the new tanks cost many dollars more! Once I get the new valve tanks I can get them filled anywhere.
    I did ask if it mattered and was told no. The company handling the tanks must get a hell-of-a discount on the new valves to put in the old tanks. Probably some kind of Gov subsidy, everything else is these days.
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,694
    1307
    2121
    If your tank needs a date, you can fix her right up with a set of number stamps and a few whacks of a ball pein hammer.
    <Insert Standard legal/ ethical disclaimer here>
    Jan 2005
    Salem, Ohio
    4,104
    47
    88
    Cool
    New Valves are cheap from http://www.mcmaster.com page 3331. I have changed about 30 of them...Bob
    Replacement Valves for Bulk Propane Tanks
    A perfect replacement for your existing bulk propane tank valves. All meet NFPA 58 requirements. Note: These valves are not for the 7777A lift truck tanks on this page.
    Valves for 10-, 20-, 30-, and 40-lb. capacity tanks are Type 1 valves equipped with an overflow protection device. Inlet is 3/4" male NPT. Outlet has both an external 1 5/16" Acme Type 1 connection and an internal female POL (CGA510) connection. Valve for 100-lb. capacity tank is a standard tank valve with a 3/4" NGT inlet and a female POL (CGA510) outlet connection.
    For Steel For Aluminum
    Tank Dip Tube Cylinders Cylinders
    Cap., lbs. Length Each Each
    10 4.0" _______ ___
    65945A13 $19.14
    20 4.0" 65945A13 $19.14
    65945A14 • 23.86
    30 4.8" 65945A14 23.86
    _______ ___
    40 6.5" 65945A15 23.86
    _______ ___
    100 11.6"
    Bob Wright Metal Master Fab
    Salem, Ohio Birthplace of the Silver and Deming Drill, all others are copies.
    Feb 2006
    SW PA
    6,027
    1266
    726
    I've taken all my old ones to WalMart to exchange them. They take the old style valve and give you a new Blue Rhino in exchange. Actual cost is less than the price above for a valve, and it is full of gas.
    Also, I know we can do anything, here, but it takes a good hold on a thin shelled tank body to hold it tight enough to remove, replace the valve.
    Think the last time, a couple months ago, the price was either 17.84 or 18.76.
    Cheers,
    George
  11. #11
    Jan 2005
    Houston
    4,992
    263
    1859
    If you wanna get down
    Get down on the ground
    Propane.....
  12. #12
    Sep 2006
    SE PA, Philly
    5,087
    907
    1569
    Quote Originally Posted by Craig Donges View Post
    Industrial welding and cutting tanks are not covered by NFPA Pamphlet 58. Don't know if there are other codes or standards.
    GregSY, your reference to that song is hilarious. Imagine Hank Hill singing it! With your permission...
    If you wanna hang out and you've got to cook out; propane.
    If you want something browned, put your grill on the ground; propane.
    She dont lie, she dont lie, she dont lie; propane.
    Tofu is bad news, sizzlin' meat kicks them blues; propane.
    When your day is done, you want grilled dogs on a bun; propane.
    If your steak is gone, you want a brat with onion; propane.
    Dont forget this fact, dry rub your rib rack; propane.
  13. #13
    Feb 2008
    south west Florida
    50
    Quote Originally Posted by bosleyjr View Post
    No, your song is hilarious!
    Cat
  14. #14
    Jul 2008
    Philadelphia
    1,860
    487
    409
    BosJR,
    Your a poet if you don't know it. Rock on man!!
    Heh post 69 thats my birthday 1969
  15. #15
    Feb 2004
    Metuchen, NJ, USA
    5,367
    4004
    799
    That was GREAT ! I'll never look at a propane tank without thinking about that ditty and smiling !
  16. #16
    May 2007
    Vancouver Island
    255
    12
    Default to GMATOV (no.10)
    Just a warning, up here, I've taken and exchanged for the same reasons as you at Canadian Tire. I found that I have to check the date stamp on the tank because (I've been told), those tanks that have replaced valves are only good for five years not ten with a new tank and valve. Wayne.
  17. #17
    Mar 2002
    Bemidji,MN USA
    355
    10
    30
    Quote Originally Posted by Machinery_E View Post
    Thanks!
    Eric
    DOT requires that all LP tanks 45# capacity and under be equiped with an OPD(over fill protection device) valve. NFP 58 does show an exemption for "industrial welding" tanks. DOT regulations also list the criteria for re certifying LP tanks..deep dents may be cause to reject the tank. If the dents are more than 10% deep than the length of the dent the tank should be rejected. Part of re certifying Lp tanks(12 years after original date of maufacture and every five years after that) is filling out forms..the forms ask for, among other facts, date of manufacture, maufacturer, DOT #, condition of tank as to dents, condition of foot ring, leaks, covering(paint),excessive rust etc. In other words.. if your tank has a few small dents but is in otherwise good condition AND you stencil "For Welding Use Only" on the tank any propane dealer should be able to re certify and fill you tank.
    I do this for a living and have changed out literally thousands of old valves and retrofitted them with OPD valves..no sweat, no hassel..pay $11.00 for a 20# tank valve and be on your way.
    Steve
