I had a job tonight to fit a bearing into a tube with a shaft inside the bearing.
Had to press both at the same time.
Should I push on the outside diameter or the inside diameter?
I went for the outside but is there a rule for that?
Jeff
I find a flat washer that will span the inner and outer race, then use a pipe to press both at the same time.
If you applied the pressing force through the balls to the other race, You have ruined the bearing. Period. Full stop.
You always press on the ring that is the interference fit. If both bore and shaft were press then you need to press both simultaneously.
Notice
