Michael Moore
Titanium
- Jun 4, 2004
- San Francisco, CA
How is this typically done without CNC equipment?
For example, I think some bucket tappets, while nominally flat, actually have a very large radius on the rubbing surface (40-70" is one set of numbers I've seen mentioned). I can see a small radius being machined/ground with a Holdridge ball turner kind of arrangement, where the machined surface or the tool tip is 2-4" away from the center of arc. I suppose this is how a finger follower with a 2-3" radius is done -- the follower surface is set at the radius on a rotary table and is then swung past the tool, or vice versa.
But that kind of operation seems unlikely if you have a 40,100 or 150" radius. Soon you start needing lever arms that pivot in the next building or a rotary table that can pass as a flying saucer.
Is there some kind of marvelous compound lever mechanism that is used to generate a large radius without needing to actually swing something at that radius?
cheers,
Michael
cheers,
Michael
