What type of cutter is the large facing tool pictured? What speed should it be run at? Its 2-1/4" in diameter. Can these be sharpened? its not in the best condition.
What speed should the saw cutter be run at? It's 3" x 1/8"
Is there a formula that can be applied to calculate these speeds depending the material I'm cutting. I'm usually working in mild steel and aluminium.
Thanks.
Thanks.
