I am about to mount an Aloris qctp (Thanks Jon!) on a lathe that has no t slot on the compound. The original 4 way post has a press fit stud with a boss on it that stabs in from under the compound. I can make a hollow bolt to attach to the original stud or I could tap the compound to thread the included 9/16 Aloris stud directly into the compound. Thj e other option would be to bore the compound hole to accept the 9/16 stud and make a nut that presses in the bottom of the compound.
The reason I ask is I am) 9naturally inclined to go the easy route and tap the compound to accept the included stud. But I think there is a reason lathes that do not have a t slot in the compound always use a stud with a boss or shoulder vs threads. Could threads distort the compound and bind things up? Or could the compound end up with a lump where the threads have been pulling on it?
I know the hollow bolt solution will work but a 2 piece solution seems less rigid.
This is mounting on an Emco Maximat super 11. Thought I should mention that before someone cries Chinese hobby machine
