1967marti
- Nov 13, 2011
- Austin, TX
I plumbed my shops air supply with 3/4 copper. Love it, easy to install and and cools the air pretty quick over the 40+ feet or so that it runs.
I installed motorguard brand filters/regulator combos as well as desiccant dryers and motorguard M60 filters for all the cnc machines and plasma drops.
Issue is, the motorguard filter/regulators are junk, and I'm swapping everything over to NORGREN brand separate filters and regulators. Because I mounted all the filters to studs and then hard-ran the copper to said locations, there is no easy way to remove the motorguard equipment without damage to the copper piping.
I'm having to cut into the copper to remove and replace the old filters and regulators. Is there any good copper unions that I can use to make future maintenance and replacement of filtering equipment easier? Or should I just hard-run the copper to the new equipment (as before) and plan on repairing the copper again if I ever need to replace equipment in the future?
Most of the box store pipe unions have crap reviews. Is there a brand you guys/gals recommend? Or, is it just more cost effective to hard-run everything again?
