gear cutter
Cast Iron
- Oct 16, 2010
- MO, USA
Has anyone worked with Nichroloy? If so, what can you tell me about it. How does it machine? Will I need to get special tooling? I have never worked with it and I do not want to learn anything about it the hard way right now if I can avoid it. The job in question is machining a 12' shaft 4.5" O.D. A 2.999 journal on each end and turn one end to 3.875 O.D. 90" in length. Two keyways, one at each end.
