SLG
Cast Iron
- Jun 4, 2014
- New Mexico
This is not just for engineers, anyone is welcome to chime in
I've been asked to study/possibly build a special load-positioning device for use with a knuckle-boom crane.
Below are two simple drawings.
In the upper drawing, the knuckle-boom crane is carrying a piece of pipe 20 feet long and weighs 3,000 lbs. The pipe is suspended by chain. This arraingement cannot get the pipe into the required position.
In the lower drawing, the same pipe is perched atop a (proposed) 3-axis load-positioner and sits 4 feet above the centerline of the crane. All motion is hydraulically controlled and allows for precise positioning of the pipe.
The crane is rated 6,000 lbs at this distance. The positioner would not have any manufacturer's data affixed to it, nor even available. The work area, of course, would be coned and roped-off.
Assuming the load is well-balanced and properly handled, is the crane subject to any abnormal forces or potential damage in any way?
Would a construction-site safety man or an OSHA rep freak out if they saw this?
Do you see any reason why this device would not work, or would be dis-allowed on a jobsite?
Please note: I am not looking for alternative means of lifting/positioning the pipe - only input regarding using a crane in a way that is maybe a little out of the ordinary. THANKS
