Quincy Compressor Paint Color
Results 1 to 16 of 16
    Oct 2003
    Philadelphia, PA
    884
    87
    Default Quincy Compressor Paint Color
    I've seen Quincy compressors in two colors, 1) a light creamish color with a faint hints of green, or 2) a deep blue similar to Miller welder stuff. Was that an option when you bought the compressor or is that some sort of chronological indication? By that, I mean, can I glean any date of manufacture info by the color? Was there some time period when they switched from the cream to the blue? Is it as simple as the cream ones are older and the blue ones newer?
    The creamish looks like this (except for the blue unloader):
    A here's the blue:
    And here's one that appears to have started with the creamish color and got repainted blue:
    Is this an age indicator, a factory option, or something else?
    Apr 2004
    Modesto, CA USA
    5,708
    844
    mine is blue, made in the 80's. Aluminum serial number plate held on by double stick tape. I repainted it with tractor supply paint ford ,might have been new Holland, blue. Perfect match.
    I think the cream is much older, at least 60's
    Bill D.
    Jun 2007
    Amarillo, TX
    1,121
    10
    36
    And there's yellow Quincy 230.
    Oct 2003
    Philadelphia, PA
    884
    87
    To me, it seems like it might be date related, but I can't be sure.
    There's pretty much a forum for just about everything these days... Is there an old air compressor forum?
    Shawn, Do you think that 230 was yellow from the factory, or was that a previous owner modification? It looks like there might be some blue peeking out in the belt grooves on the flywheel.
    Jul 2006
    Indiana
    539
    257
    85
    Two data points. I have a Quincy 308 - early 1970's according to the parts list I have - It's blue. And I have an old 2-stage of about the size. It's old enough to have been fitted with a flat belt pulley. It's yellow...
    May 2006
    Seattle
    1,558
    26
    272
    It's age. If you look at the plate on the crankcase of your Quincy pump you will see two numbers. One is the model number; the second is "record of change". Example: 325 27 means model 325 pump, record of change 27. I owned a 5hp 2-stage Quincy compressor for years. It had a model 325 air pump, record of change 16. I did some work on it, and when I'd go to my local Quincy service center to buy parts, the old guys there would groan and wag their heads at the ancient record of change number dating from the 1960s. But they still had parts! Anyway, Quincy guys can go from ROC numbers to production dates. And machines dating from the '60s and '70s were green and later were blue.
    The pump shown above looks like a model 325 to me, except its unloader valves are unplumbed. There are supposed to be fittings and 1/4" copper tube going up from the oil pump. My guess is that that pump was rebuilt. There are various configurations of unloaders (see the manuals, all of which are downloadable from the Quincy site) and obviously they didn't know what configuration the buyer of the rebuilt pump would need so they didn't do anything. But the ports on the unloaders should be capped off to prevent corrosion inside the intake valves.
    metalmagpie
    Oct 2003
    Philadelphia, PA
    884
    87
    Those pics aren't my stuff. I found those shots in some of the other threads on the forum here. They're just color examples. Here's the threads in which those pics were originally used:
    Quincy 325 Compressor Help.
    Quincey 216 rebuild q's,....
    Working on Quincy 325 - Got Some Questions
    I've currently got a blue 325 ROC 18 and a cream colored 310 ROC 26. I've looked through the literature available at Quincy's website and have downloaded the parts books for each.
    Sep 2007
    Woodinville, WA
    1,704
    186
    346
    The blue unit above is MINE and it's from 1999. I had a 216 from the early 80's at was factory painted with a "gold" color.
    Mar 2006
    Vershire, Vermont
    1,731
    980
    468
    Quote Originally Posted by Lakeside53 View Post
    Nice plumbing job, Lakeside. Both air and electrical.
    I've never seen an oil filter on a Quincy. Is that a "Lakeside special" or a factory feature?
    neil
    Oct 2003
    Philadelphia, PA
    884
    87
    And I still think it's a beauty! Thanks again for posting that pic.
    I haven't called Quncy to ask for more detail about mine, but from the dates on the different parts books for the respective ROC's I believe both my 325 and my 310 are from the mid seventies to early eighties. Seems they were from right around the threshold from creamish to blue. (And yes, the cream looks a little gold in some lights. I believe we're talking about the same color there.)
  11. #11
    Oct 2009
    Portland, Oregon
    3,596
    3844
    1766
    Quote Originally Posted by neilho View Post
    neil
    The QR series Quincy's have been built with pump mounted oil filters for a couple decades now.
  12. #12
    Mar 2006
    Vershire, Vermont
    1,731
    980
    468
    Quote Originally Posted by Garwood View Post
    Just goes to show ya how old my equipment is. Is it possible to add a filter to older compressors?
    Neil
  13. #13
    Jun 2007
    Amarillo, TX
    1,121
    10
    36
    Neil
    Somewhere I saw an article about upgrading the oil pump with the filter.
  14. #14
    Jan 2014
    Northern California
    I just got a trailer mounted, engine driven 325 ROC-10 that was sitting on top of dump trailer on its way to the scrap yard. I almost had to throw myself in front of the truck, but it's now in my shop. Changed the oil in the engine, checked the oil in the pump, hooked up a battery and it runs perfectly! So now the task is converting it to 5hp electric. It's got the dual unloaders for continuous operation with the 9hp Wisconsin. Re: the paint color. Under the peeling red paint that's on the whole unit, it's blue. ROC-10 is a 1963 machine according to the Quincy tech.
  15. #15
    Oct 2003
    Philadelphia, PA
    884
    87
    Cool! Any idea why it was headed to the scrap heap? The guys dropping it off have any info?
  16. #16
    Jul 2007
    west central illinois
    37
    11
    Hi, Tim here. I live an hr. from the factory(Quincy, Illinois). My mentor purchased his (now mine) new in Dec. 1964. It has had a gentle life as we only run it 6-7 days a month for the air bearing work( tool and cutter grinding shop). Ours' is the aqua marine blue. Have a great day.
