oregondave
- Dec 8, 2017
After years and years of buying (all the way from bare land, to tractor, to building my house and then shop) I'm ready to learn the basics of machining and I believe I have all the right tools and machines to start out doing serious learning on my hobby setup. My goal is to learn, incrementally (by making mistakes and improving one by one) each and every aspects of manual non-cnc machining and I need help, direction, information, inspiration to reach these goals.
Tools/machines I have: (you can see a common theme here, bottom of the barrel cheap hobby stuff that I can afford then later one day buy the real things)
Lathe - 7x14 Harbor Freight (3" chuck -missing outside chuck, but have faceplate) [don't laugh I have to start somewhere], ~$200 basic tooling
Milling Machine - Little Machine Shop Hi Torque Mini lathe 3990, 12" X axis .0004", extra tools, heavy duty vice, R8, most tooling
Waste Oil burner, smelter, crucible, basic ingot and simple mold creation, home made from scrap (siphon design)
Plasma Cutter (CUT-50), MIG ( Harbor Freight 90 amp, crappy AC, Fluxcore), $200 Amazon Prime 160 amp DC stick welder (works amazingly well). No TIG welder yet.
Angle grinders, carbide saw, bench grinders, cut off tools, bunch of Arduino and CNC boards, stepper motors, RPi's
Loads of scrap aluminium, and a barrel of scrap steel, standard shop stuff, calipers, blue dye. I do not have a surface plate , I could use a piece of glass. I do not have a machinist carbide chisels ($200???), I could buy a carbide blade and weld it to something with a handle.
So basically, I can infinitely melt down my failed aluminium projects and start again on any project, be it will be made of soft aluminium. My goal is to one day have a real setup with a Bridgeport, modified for CNC, and a nice heavy duty iron lathe, all the $2000+ welders/plasma cutters. I would also like to be able to cast iron. but for right now, I think I have basically everything I need to learn at a hobby level -- nothing should be stopping me except my imagination and motivation. This is a huge accomplishment getting all these things together with my income and took years (yes I know this is the cheapest stuff, I'm a small farmer which means I'm always broke). Of course I won't be making a living with the tools I currently have now but my occupation is farming and it is the winter time right now. Money is really tight and one thing I wish I had right now was a copy of the Machinist Handbook to put next to my bible in my bedroom (haha just kidding), but the books are very expensive. I sometimes old ones on ebay for cheap, and the really old original is on PDF somewhere on my hard drive.
So, what should I do?
Where can I start learning all the techniques I need to know to one day be an expert machinist?
If you were to go back and tell yourself what you know today that you wish you had known when you started, about learning the basics and each technique, what would you tell that person?
