CatMan
Hot Rolled
- Apr 12, 2005
- Brandon, MS
I've got an application here where I need to blow air through a part ( for cooling purposes ) and then pressurize the part to check for leaks. I plan on using a solenoid valve close the system off when the leak test begins.
I'm looking for recommendations on the best brand/kind of solenoid valve that will not leak. I've considered putting two valves in series so if the first one did leak, the second one would catch it. Air pressure is only going to be about 60 psi.
