Pete F
Titanium
- Jul 30, 2008
- Sydney, Australia
G'day guys, I guess this is stupid question of the day time
I'm about to buy a surface plate and am not sure what size to get. Obviously "bigger is better" but it could come at a price. The size options I'm looking at are (in metric) 400 x 300 x 70 mm at 46 kg or 630 x 400 x 100 at 93 kg. Both are specced 00. At first I was just going to get the larger one, however once I actually saw the area it would take up on the bench I started to wonder about the amount of real estate it was going to take up! The weight is also a significant point as I would like to keep it as level as possible for balancing things in addition to spotting/measuring and it sits on an MDF bench that may sag slightly with sustained weight (I've had that happen before and that was just a 25 kg vice!). Installing and moving anything over about 40-50 kg just becomes a bit of a PIA by myself in my book, getting a 93 kg into my little Alfa sedan, home, and installed by myself could be interesting just in itself ... the joys of being a scrawny weakling
The purpose at the moment for it is in renovating/restoring a SB 9" lathe. I've heard some say even a 9 x 12" plate is enough, others say no you will need a larger one to construct/maintain straight edges to do the bed. Once the lathe is finished I will be installing a (small for you guys) Sieg X3 mill and will probably go over that also when I get it. Other than that, these would be the largest machines I could imagine working on and the parts I make and measure are generally quite small.
I'm starting to lean towards the smaller plate if it will do the job, and figure I can always sell it on ebay if it turns out to be just too small but thought I'd ask you guys for some expert opinions.
Thanks for the help.
Pete
Pete
