the races are usually hard enough you can just crack them with a punch
I've yet to see races I can't file nowadays. And they're stuck in the bores, not on the shafts.
Stuck on bore: three best options: Weld, Weld, Weld.
weld a bead or just heat a puddle with TIG around the race and once it cools it will fall off without any help.
1. I think some pictures are in order here if for nothing else just to clarify things. First post says you need to chop them off and later it's stuck in a bore?
2. I haven't met a bearing yet that if it was installed by someone it couldn't be uninstalled; Show me something new.
Dan
Yeah, that . . . and if you want to protect the internals from weld spatter - get some Pillsbury biscuits in a can and press the biscuits into the void just past the race - then weld away, the biscuits will catch the spatter and cook / expand to keep the seal, when the race falls out, just pull the biscuit out and throw it away.
Learned this from a fellow old truck nut and this has made removing bearing races from hard to reach transmission bores go easy without getting a bunch of contamination in the transmission.
Can't put heat in those bores. There are remnants of an old pin inside - can't try press/bang them either. The wedging effect will throw the bores out of round. "Chopping" is the only option.
Sounds like your mind is made up already, WTF are you asking, get busy with your grinder then.
Are you fucking retarded ? Have you read post no 1 here :
"""I've got two BB's I need to chop off - no other way to remove them. Around 100mm OD. I'm curious if anybody has a good procedure or tool suggestion for this. In the past I used a die grinder with a round grinding stone. But it took forever."""
Try reply to the actual fucking question asked not to what you think you understood from others' replies.
Expanding puller and a slide hammer.
Sent from my XT1053 using Tapatalk
Notice
