Bill D
- Apr 1, 2004
- Modesto, CA USA
I have a yellow jacket vacuum pump. It uses an internal splined rubber sleeve between the motor and pump. It split and threw the sleeve off today. All I can find on the Ritche site is a spider type drive coupling. Which should work but I would rather not have to remove and adjust the drive ends if I can just buy a new sleeve. Where can I determine what size I need and where to buy one. The pump is US made so I assume this is all English size shafts.
Bil lD.
looks like this, not sure if this one would fit at all, just a picture for you.
Urethane Sleeves, Size B, Gear Grip, Flexible Shaft Couplings (1 Each): Gear And Sleeve Couplings: Amazon.com: Industrial & Scientific
comes in sizes A through E but no mention of dimensions.
Bil lD.
