Removing a Rohm chuck on a vintage Lesto drill
Results 1 to 14 of 14
    Dec 2006
    Oslo
    128
    5
    Default Removing a Rohm chuck on a vintage Lesto drill
    Hi guys,
    I have a severely worn out Rohm keyless on a nice low speed old Lesto hand drill (early 50's?). There's no screw inside the chuck, and the screw on the collar towards the drill body is worn out so much that tightening it is not possible. Holding the drill by the chuck in a drilled out and split wooden block and giving it a counter clock-wise whack resulted in the loosening of the outer sleeve of the chuck. So now the question is: Is it screwed on, or is it a Jacobs taper? Any advice/experience out there?
    The drill in question can be seen here:
    Kind regards,
    Truls Erik Johnsen
    Johnsen Frameworks
    Hølen, Norway
    www.johnsenframeworks.com
    Johnsen Frameworks | Facebook
    Jan 2007
    Norfolk, UK
    16,540
    12172
    11606
    More than likely screwed, IME taper fittings on pistol drills ate very rare.
    Looks like the collar where it goes on the drill is split with an allen screw to lock it on- remove then;-
    This is my method.
    Grip a TEE (an old chuck key??) in the chuck and rap the end with a hammer in the loosening direction, 2 or 3 raps is usually enough,............ unless you've had some muppet put it on with Loctite
    Feb 2006
    Indiana
    11,738
    396
    2968
    If the Rohm chuck is built like an Albrecht, then you can replace the jaw set by simply unscrewing the hood on the front of the chuck. You have the hood loose, so check it out. Albrecht jaws and other parts are easy to buy in the USA, but I have never seen anyone selling Rohm parts. Maybe you can find a source in Europe. If not, try to find a new Rohm chuck of the same model, without regard for the Jacobs taper or thread mount. Then you can transplant the jaws and hood and possibly other parts without needing to get the chuck body off the drill spindle.
    Larry
    Dec 2006
    Oslo
    128
    5
    Thanks for the advice, guys. Got it off tonight. Turned out to be a Jacobs taper. The chuck is most likely a goner, but I will try to take it apart now.
    Truls
    Dec 2006
    Oslo
    128
    5
    Short follow up question on the taper: A quick measurement with a caliper this morning shows that the large end is 12mm, the small end is 11,2mm and the length of the taper is 20mm. As far as I understand, this does not correspond to any of the measurements provided by Wikipedia on Jacobs tapers: Machine taper - Wikipedia, the free encyclopedia
    Does anyone recognize this taper?
    Truls
    Dec 2006
    Oslo
    128
    5
    Jan 2007
    Ohio
    247
    48
    54
    JF, you should contact Rohm to see if they can overhaul your chuck. You might be surprised, the Albrecht people here in the US told me that their precision keyless chucks are almost always rebuildable, and I think the Rohms are similar. Good luck, Bill S
    Aug 2016
    UNITED KINGDOM
    Default Lesto drill chuck
    Quote Originally Posted by JFW View Post
    Truls
    Hi, I am hoping to revive this thread, and that perhaps Truis found the answer to this query. I am in an identical situation. I have a fully functioning Lesto drill, similar to the one in the photo above, which had a seized chuck. I have not been able to free it, and it is in somewhat worse condition than when I started. However, I have been able to remove it, with just one tap from a cold chisel.
    I do not know the fitting, which I need to identify to fit another chuck. The shaft appears to be the same as for Truls drill, virtually straight. Anybody have an idea?
    Feb 2006
    Indiana
    11,738
    396
    2968
    Quote Originally Posted by greenstar View Post
    See post #6, which said the taper is B12. That is a European taper seldom seen in the USA, but probably very common in the UK.
    Larry
    Aug 2016
    UNITED KINGDOM
    Thanks for pointing this out. There are several B12 chucks on the Bay, so I guess you are right. Should be able to fit one.
  11. #11
    Aug 2016
    UNITED KINGDOM
    Just a thought - can anyone comment on the quality of the Chinese keyed chucks? These are on offer at about 6 - 10 uk £. I have a rather tight budget at the moment. There are German types of keyless chuck at around £20, but given these are precision jobs and keyless the price difference is believable, and I have always found keyed chucks adequate. I keep seeing threaded types at car boots, but a B12 would I think not be easy to identify or find.
  12. #12
    Feb 2006
    Indiana
    11,738
    396
    2968
    I have some China-made keyed drill chucks, copies of Jacobs ball bearing super chucks. The box has the Golden Goose brand name, but the chuck has a picture of a pelican (pouch under the beak) stamped into the steel. I am using a 1/4 inch size that is extremely accurate and finely finished, nicer than any Jacobs chuck I ever owned.
    But I have seen other no-name cheap chucks that were rubbish and disposed of accordingly. Don't know where they were made because I did not buy them new.
    I have some very nice-looking Spanish copies of Jacobs chucks, but have not used one. New Jacobs chucks are made in China and are said to be rather dodgy, quality-wise.
    I would hesitate to put an expensive new chuck on an old drill motor which would not be worth $10 in the USA. I expect UK prices on old tools are different.
    Larry
  13. #13
    Oct 2013
    netherlands Asten
    742
    427
    303
    Quote Originally Posted by L Vanice View Post
    Larry
    That Lesto has outlived generations of newer hand drills and will continue to do so for many more generations.
    They were built in Switzerland, up to a standard not down to a price.
    Put a quality chuck on it and you will have a machine that is probably better than anything in the market today at any price.
  14. #14
    Aug 2016
    UNITED KINGDOM
    I appreciate the quality of the Lesto. I don't give two hoots what the market price is - the fact is that it is a good drill, and excellent design. People don't always appreciate fine things, but I find myself it a pain when they become very collectable and spend their lives in a display cabinet because they have monetary value.
    My problem is I am living on £60 a week at the moment. I don't see the issue in putting an inexpensive chuck on? From what Larry says some Chinese chucks are pretty good. What is a quality chuck? I see prices from £18 to £50 for keyless. Surely a replacement be removed if it wasn't any good, or when I come across something better. At least the drill will be useable. Is fitting a cheap chuck likely to damage the drill?
