Removing rust from car brake caliper dust seal groove
Results 1 to 18 of 18
    Feb 2009
    London, England
    438
    32
    Default Removing rust from car brake caliper dust seal groove
    What methods can anyone here recommend for removing the rust from the outer dust seal groove on cast iron brake caliper bodies?
    Also, what would be a suitable coating to prevent or at least delay the rust from returning?
    The shape of the caliper body makes access difficult for one side of the groove.
    Is it simply a case of scraping it out by hand using a suitably ground piece of steel?
    Thanks for any replies.
    Sep 2004
    RSA
    1,060
    383
    253
    Quote Originally Posted by Webley91 View Post
    I'd use a small brass brush. I'd try clean as best as I could with whatever is most convenient but I wouldn't worry excessively.
    Jan 2007
    Mountain Home AR.
    84
    9
    50
    For single piston calipers we used a Dremel too with a small wire brush. For dual piston calipers a small stainless wire brush works OK but a PITA unless you want to split the calipers so you can use the Dremel tool. You could paint the groves with high temp paint used on calipers, I never tried that though.
    Jul 2014
    Ontario, Canada
    866
    631
    558
    Just use a brass brush as per above to avoid damage to adjacent surfaces, like the seal. Put a light coat of silicone brake caliper grease on the cleaned surfaces to prevent rust.
    Like Alex said, I wouldn't worry about it. It's a brake caliper- in 10,000 km it will be disgusting again.
  5. Likes Scottl liked this post
    Jul 2014
    MI USA
    707
    189
    291
    Have a look at this thread.
    Caliper cleaning example.
    Evaporust making my own report so far.
    I like to use acid wash primer to coat my undercarriage parts for preservation.
    SAF Ω
    Oct 2005
    erie,pa
    8,984
    16029
    4553
    Mask (or turn a rubber plug) and glass bead blast.
    Nov 2013
    Eastern Massachusetts, USA
    3,813
    3553
    3368
    Quote Originally Posted by RC Mech View Post
    What he said. Unless you want to coat it as a "show" caliper behind wheels with large openings I wouldn't waste the time to do more than make sure it is in peak mechanical condition.
  9. #8
    Feb 2009
    London, England
    438
    32
    Thanks for the replies.
    The rust in the outer seal cavity is quite jagged, and I don't want to damage the outer seal on reassembly. I have a full seal kit and will be replacing all of the seals.
    Unfortunately I don't have access to any bead blasting equipment.
    I am reluctant to submerge it in any kind of chemical bath as these calipers have a built-in handbrake mechanism and contain a roller brearing. Apparently these bearings are not available as a spare part, and there doesn't appear to be any way to remove them without damaging them.
  10. #9
    Dec 2010
    WA, USA
    1,512
    2005
    1030
    If I wanted to remove the described rust, I would disassemble to the maximum degree practicable and soak them in Evaporust. It won't damage your bearings (assuming they're made of steel).
    If it's a British designed component proceed at your own risk. Out of curiosity, please translate "roller bearing" into American English or provide a picture of the type.
  11. #10
    Jan 2003
    E. TN USA
    1,501
    48
    126
    "If it's a British designed component proceed at your own risk. Out of curiosity, please translate "roller bearing" into American English or provide a picture of the type."
    http://d315rp2pq5jxiy.cloudfront.net....NE.186069.jpg
  12. #11
    Oct 2010
    Maryland- USA
    2,771
    1423
    1726
    In the states a exchange for rebuild is so inexpensive that I no longer mess with them- just exchange and get on down the road..
  13. Likes Bobw liked this post
  14. #12
    Mar 2011
    Kansas
    878
    105
    243
    On my calipers for a 60's Fiat I just made up a steel scraper and carefully cleaned them out, they were 3 piston units that I had split the calipers. Replacements were available but cost more than the car is worth. I wasn't going for show but just for function, they got new seals, dust boots, and pistons. Put in in a vise with some good light and have at it.
  15. #13
    Feb 2009
    London, England
    438
    32
    Quote Originally Posted by extropic View Post
    It is actually a Japanese caliper. It is from an imported Japanese spec 4x4 vehicle that was never sold in the UK with these particular calipers. They are not available as exchange units.
    For roller bearing I mean this type of bearing. The bearing fitted to the caliper is an open-cage type as shown in the picture. The size fitted to the calipers is apparently not available to buy.
  16. Likes extropic liked this post
  17. #14
    Dec 2009
    628
    458
    433
    We used to use walnut shell in the blaster for that and similar applications.
  18. #15
    Apr 2004
    Modesto, CA USA
    5,479
    778
    Living in the almond capital of the world I wonder if they ever use almond shells for blasting? I would guess they are softer then walnut shells.
    Bill D.
    modesto, ca, USA
  19. #16
    Oct 2016
    Wisconsin
    34
    6
    11
    smell better too?
  20. #17
    Aug 2003
    New York
    94
    12
    I believe bead blasting is the best way to go. If you can't do that I've used a stainless steel tooth type brush followed by 150 or so grit emery folded to fit groove. Before reassembly coat all surfaces with Dow 111 silicone grease. Grease is heavy (thick ) and stays put pretty good. I also use it on the mounting surfaces of brake rotors and calipers. Makes the next brake job faster as there is much less rust to remove. My wife drove a rural mail route and I would do brakes every 8 weeks... I needed to make it a little less labor intensive.
  21. #18
    Aug 2010
    Minnesota
    1,372
    128
    1042
    For $50ish a caliper let the reman people deal with it. Comes with new seals and a warranty.
