removing static from plastic
Results 1 to 10 of 10
    Mar 2006
    connecticut, USA
    356
    6
    Post
    What is the best way to remove static electricity from polypropylene, or any plastic for that matter? I can't induce a charge on what is going to be touching it.
    May 2006
    NC
    682
    40
    31
    Post
    Add humidity.
    Mar 2002
    178
    Post
    Have a grounded whiskered pickup in touch with the surface of the plastic. This needs to cover a large area as possible. These are often found in such products a laser printers which discharge static electricity from moving paper sheets just before they exit the printer.
    May 2006
    Longview,TX
    1,002
    6
    Post
    Wipe it with the anti cling sheets that go in the dryer,an ols trick reloaders use to stop powder from clinging to plastic powder funnels
    Dec 2004
    uk
    12,407
    3429
    5531
    Post
    one of the sign places i go to has the biggest buble jet printer i have ever seen. if there doing plastic sheets with the protective film, peeling the fim off creates anough static to repel the ink! it litraly floots off!! they use a ion pump and it works brilliantly. its like a vacume cleaner that blows! simply wave nozzel over charged object and charge has gone! i can also tell u thoes conductive brushes on the end of copyers help lower the static but theres a lot of charge left!
    can u tell us more about the job it would help to know a little more if u can say?? like that u might get a better answer.
    Aug 2006
    New York
    537
    6
    Post
    Get an ion gun. Google antistatic gun or ion nozzle .
    I used to have an old EnerJet that attached to a compressed air nozzle, but it died and I can't find parts for the generator box.
    Nov 2003
    Colorado
    3,211
    1967
    3843
    Post
    Aug 2004
    Springfield Mo
    411
    8
    52
    Post
    Try spraying on a diluted solution of water and dish washing soap and do not wipe it off. It will form a film that controls the static buildup.
    The early attempts at static electricity control used a similar method in the aerospace/missile plants.
    Dec 2003
    Albuquerque, NM USA
    566
    5
    Post
    Well there is the antistatic brushes that use to be
    available in the photo business, to get rid of
    dust or lint pickup on negatives to be printed.
    It was a Polonium strip with a brush atached.
    Of course now that the Russian defector in England
    was killed with the stuff it may be hard to find.
    ...lew...
    May 2005
    Australia
    171
    Post
    'Lathefan's post pretty much sums up what I could suggest.
    Also try HiFi stores - as lovers of vinyl records often use a spray that removes static charge without leaving any significant film which would interfere with the groovy tunes.
