DieselPower
Cast Iron
- Mar 28, 2009
- Centerville, TN USA
Help! My collet set is ejecting tools, and I cannot keep them in. I'm trying to hold a 1" end mill and cut a long slot. The cut ends up being about .150 deeper per inch. I have cleaned the collet and mill in acetone, lubed the collet holder taper and threads making sure not to get oil on the inside of the collet, tightened it until the wrench broke, made a new and improved wrench, tightened some more, and still have problems. There is no chatter, just a nice smooth cut, running 900 RPM with .0025 chip load. If I keep the cut less than .250 deep, it does OK.
I've already ruined a big piece of 4140, and chipped my $130 cutter
The collet set IS a chinese set I got on ebay, but I was pleased with them until I had to do any heavy cutting. Runout is good, everything is clean and not damaged. What can I do?
