dbooksta
- Sep 28, 2016
- Philly suburbs
I have been using 5/16-18 hardened UNC 3A screws to fine-tune the elevation of a steel jig. But they're bearing on a 3/4" flange of mild steel, which is developing a bit of slop – maybe because the tapping wasn't 3B to begin with, or maybe because the hardened screw threads are wearing on the softer steel threads.
I'm trying to figure out if there is a way I can fix or improve this. Here are three thoughts:
- Restore the tightness to the hole threads? I tried using blue loc-tite for this, but that just makes it harder to turn the screws, and doesn't actually tighten the fit.
- Drill out and replace the tapped holes with a hardened threaded steel insert. I haven't found the right one, but I'm suspect there are good options out there.
- Is there a better approach for precise elevation adjustment on a roughly 50-pound jig than this flange-and-screw?
