Log this under....I don't want to know.
Yup trigon, a much latter addition.
Original spec drawn up by the Cemented Carbide Producers Association and submitted to ANSI. (Carboloy, Firth, Kennametal and a few others)
Easy at first as there where Squares, Diamonds, Rounds, Triangles .
(interesting on Corta, thinking more grab a letter below the D)
Eight letters/numbers:
Shape, clearance angle, class, type, size, thickness, cutting point, other.
Then manufacturers started adding new stuff. Some became part of standard, others industry standards, and some just bastard.
The eight position or tail of the size number being other became a wild card for any insert maker.
In the third is also U which is utility, R which is rough molded with grind stock all over and S which is grind stock top and bottom with IC pressed to sized.
SNR-430 makes perfect sense to me and on many of my POs, not so much sense to end users as it becomes something else once processed.
Tolerance of the class in M and U depend on ic size.
Simple once it is all very confusing now and while I can look at most and tell you the basic I often have to go searching more information.
Much has been added on since the late 50s and the letters sometimes are just free letters to use.
The tail end of the number can be anything from milling cutter flats to nose wipers, edge preps or special chipbreaker geometry.
A G or P in the fourth maybe radically different or maybe spelled out in number 8 as you may make 5 G's and a few P's.
It's all so confusing.....Life was easier in the day of SPG-322A.
I "get" about 80% of insert callouts, can look at most and know the letters and numbers, have to go searching many times.
Know any two chipbreakers from different companies with the same letters are not the same but I've only been exposed to this madness for a while.
Part of the deal is you want a patent on your insert. The Pez dispenser is free with some candy, but only our candy will fit.
The big K hit me on this one to the tune of $90,000 lawsuit on top-notch a ways back so gun shy here with propriety designs.
Still wondering about the OP "N" holder and if it is a "M". A picture would be nice.
Bob
