ballen
- Sep 25, 2011
- Garbsen, Germany
Hi,
I just bought a couple of used boring bars (left one shown, right not shown). These are 18mm diameter. I've ground a small clamping flat on them and will use them directly in a Wohlhaupter UPA3 boring head.
Although the bars are mirror images of each other, they came with different M3.5 screws. The one on the left has a taper head, IP15. The one on the right is flat head and T10. Which type of screw is correct? Does it depend on the inserts? It appears that the angle screws are available with a 55 or 75 degree angle. How to decide which angle is right?
The inserts are from Walter Unisix, type W28 34000.0464 BK64. The holes have a step and a rounded shoulder but are not tapered inside.
I am pretty sure that the flat head screw (which does not positively locate the insert) is incorrect but would appreciate confirmation before I order some screws.
Cheers,
Bruce
Cheers,
Bruce
