The Dude
Hot Rolled
- Oct 19, 2010
- Portland, OR
I have a question about how these pneumatic rotary actuators work. First off, you're only seeing about half of the unit, which is what looks like two cylinder bodies and a rotary axis in the middle. I'm fairly certain they can only travel (i.e. rotate) for a maximum number of degrees (based on the length of the stroke of the cylinders on the side), is that correct? After they reach (or partially reach) their end of stroke, I'm assuming they need to "back - up" before they can advance. When they do that, does the rotary shaft turn in reverse as well?
We're having some trouble with this thing, builder is long gone, hard to get access into it so just trying to get a better understanding of how it operates.
The Dude
The Dude
