loggerhogger
Stainless
- Aug 12, 2005
- Tacoma Washington
Today I had a little problem develop in my bathtub in the form of a small crack. The tub is acrylic plastic, and the crack is about 2 inches long. First off, I drilled both ends of the crack to stop the spread, and I went down to Home despot and bought some sheet acrilic made by "Plaskolite". My plan is to prep the area around the crack, and using some 5200 marine sealer/cement I want to glue the sheet down over the cracked area. Looks don't matter, since we want to eventually remove the tub altogether, and put in a tile shower. all I want right now is to get a good seal to keep the sub floor from rotting out. The area isn't perfectly flat, so my question is, can I heat the acrilic sheet with a heat gun and then form it to the profile of the area that I want to attach it to? Any thoughts would be appreciated.
