Results 1 to 11 of 11
    gradstdnt_99 is offline Hot Rolled
    Aug 2004
    USA, Midwest
    586
    Default Roll In Saw Table Inserts
    A couple years back I purchased an older Roll-In for the start-up company I was working for. After using that saw I was convinced this is a perfect saw for a small shop. I recently scored an incredible deal on a Roll-In bandsaw for myself. Unit is in excellent condition but has something I have not seen in any other saws except these two. The table has an insert adjacent to the blade. I've seen plenty of saws where the tables are chewed up as the blade somehow wanders so far off course and cuts a slot into the table. Seems like a good idea. Just haven't seen it on other saws. I'm curious to know if this is something Roll-In did or if this is something done by it's past users.
    COII is offline Plastic
    May 2011
    Denver CO
    23
    Our Roll-In does not have that but needs it. I've also looked at the Roll-In-Saw catalog and have not seen anything like that in it (almost all the parts for our saw are still available by the way). I like the idea and may do a refurbishing job like that myself. Sure beats buying a new table ($$).
    COII
    adama is offline Diamond
    Dec 2004
    uk
    4,708
    That's pretty common in one way or anouther for vertical bandsaws to have a replacable table insert. Especially wood cutting saws.
    digger doug is offline Titanium
    Oct 2005
    erie,pa
    2,072
    Every Roll-in I've seen gets that way. I think it's because the Roll-in has the capability
    to use smaller (down to 1/4") flex back blades as a contour saw, and people leave them
    intalled and use the feed motion (gravity power feed), hence the blade wander.
    I've threatened to remove the table, and set it up on the mill
    to do just that on the two I've owned.
    Aug 2004
    USA, Midwest
    586
    Your probably correct about narrow contouring blades being used in cutoff operations leading to a wandering cut into the table. The dual nature of the saw, contour and cutoff, is what made me get one. I recently purchased a 1/4" and 3/4" blade for it. Now to be vigilant about not using the narrow blade for cutoff work.
    Nmbmxer is online now Cast Iron
    Jun 2008
    Roanoke, VA
    274
    Several years ago I machined a rollin table to take replaceable inserts that we cut on a cnc plasma. It had gotten kinda hard to use with a 1/2 gap on either side of the blade. I belive it took 10ga inserts, I made them drop in a small pocket like on a table saw or router.
    Aug 2004
    USA, Midwest
    586
    My angle block has lots of cuts in it at different angles which make supporting short material flat against the stop challenging. The very sacrificial nature of this angle block, I am surprised a replaceable insert isn't offered there. A 1" blade was fitted to the saw so extra depth had been cut into this block. I'm thinking a soft steel or aluminum insert would work just fine.
    gwilson is offline Diamond
    Oct 2006
    williamsburg va
    5,300
    Possibly an in shop mod ? I have an older Roll In still nearly like new. It only had chips of plastic in it when I got it. It takes 9' blades. Newer ones take 10'. On the corners of the cast iron angle plate are holes for the clamp. One of mine got broken through. I got a piece of large angle iron about 3/4" thick and plan to make a new angle plate out of it that won't break like the cast iron one. I love the saw,but think the clamping system is very inadequate since the saw can cut large diameter round bars,but the clamp only clamps about 2 3/4" or so. Generally,I clamp bar stock with large C clamps.
    4miller1 is offline Aluminum
    Jan 2008
    okla usa
    191
    A little off topic, but here is a mod I did to compensate for the crappy depth stop on the Roll in saw.
    jeff
    Barry Weeks is online now Stainless
    Jan 2001
    Minnesota
    1,563
    I like to drill and tap a pattern of 3/8-16 holes on the table to allow for clamping down plates, etc.. Have also inserted the backstop, but never the blade slot before. I'll have to do that.
  11. #11
    Oct 2005
    erie,pa
    2,072
    Quote Originally Posted by gwilson View Post
    Like this ?
    Pix is sort of small, and from the wrong angle.
