Roll Tap Tap Drill Size
Results 1 to 13 of 13
    Jul 2007
    Curtice, Ohio
    6
    Default Roll Tap Tap Drill Size
    Hi everyone,
    I'm going to use a roll tap or thread forming tap on some spacers. The material is 1 1/4" round 6061 Aluminum. I'm expected to use a #10-32 go-nogo gage to check the threads. Some time ago, on this board, a few people suggested a roll tap to get the thread fit I need. i know you have to move up in tap drill size, but am at a loss for the tap drill size for a #10-32 thread. Can anyone give me some guidance on this one? Is there a table in the machinist handbook for example?
    Thanks all.......
    May 2004
    Zellwood, Fl.
    1,440
    587
    279
    Look in the Machinist Handbook under Cold formed threads.
    Scott
    Oct 2006
    San Leandro, California
    528
    56
    Default cold form tapping
    Hi Karl,
    Here's an online calculator to plug your numbers into.
    http://academic.evergreen.edu/projec...s-tap.htm#cold
    A #10 is .190" dia. so that figures to be .174" for the tap drill dia. if you use the figures for a standard 75% thread. A #17 drill would be the closest size.
    May 2006
    South of Boston, MA. USA
    775
    8
    Hole size is critical to get 75% thread, check before tapping. You might need to go up or down in hole size to get the right fit for the gauge. If you use the tailstock make sure it aligned with the pc.
    Jackmo
    Apr 2006
    Tempe Az.
    155
    5
    OSG has a nice online calculator also.
    http://www.osgtool.com/Technical.asp?tid=1&id=1
    Good for cut taps and form taps in both inch and mm.
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4054
    Careful there. The Karl is using a thread forming tap. It displaces metal from the hole walls to form the threads. A standard nominal dia minus thread pitch tap drill leaves too much stock. The metal will flow into the tap thread space, jamming the tap, and possibly breaking it.
    The starter hole for a thread forming tap has to be larger than for a thread cutting tap. The displaced metal fills the tap's thread space to about 75% or so. I suggest you try a few tapped holes in scrap starting with a tap drill = nominal dia minus 40% of the pitch. Most makers offer charts.
    Apr 2006
    Suffolk, England
    847
    75
    211
    My Dormer Drills wall chart gives the following formula for calculating the tapping drill size for roll forming taps:
    D(inches) - 0.0068 x H / Threads per Inch
    Where H is the percentage of thread depth required (usually 65%)
    Peter
    Sep 2005
    San Diego
    3,168
    488
    780
    Roll taps (thread forming)
    Make the pitch diameter good because they don't cut. It's the minor diameter you have to watch. Way lube works pretty well with them.
    Regards,
    Stan-
    Sep 2004
    south SF Bay area, California
    1,936
    112
    574
    Good Evening, Good People --
    This evening's sermon is given from high atop one of my very favorite soapboxes -- that understanding the fundamental geometry of the two most common threadforms, the Unified and ISO Metric threadforms, enables we of the proletariat to calculate thread-chart values for ourselves, in the absence sufficient reference material, without resort to memorized "magic numbers":
    As Forrest Addy describes, the rule of thumb to calculate the diameter of a hole to be threaded by material-removing methods (a cutting tap, single-pointing, or milling) for single-start US Standard, Unified, and ISO Metric threadforms is "Nominal Major Diameter minus Pitch". Either metric or imperial units may be used, but the same unit must be used for both Major Diameter and Pitch.
    A corresponding rule of thumb to calculate the diameter of a hole to be single-start threaded with a Unified or ISO Metric threadform forming tap is "Nominal Major Diameter minus the Single Depth of Thread", which is itself calculated from the basic threadform as "5/8 Pitch times Cosine 30 degrees". (Remember that the basic forms of the Unified and ISO Metric screwthreads are IDENTICAL . . . they both have a 60 degree flank angle, a 1/8 Pitch flat at the Major Diameter, and a 1/4 Pitch flat at the Minor Diameter.)
    I'll use a #10-32 Unified screwthread for a worked example:
    Nominal Major Diameter = 0.190 inch;
    5/8 = 0.625;
    Pitch = 1/32 inch = 0.03125 inch;
    Cosine 30 degrees = 0.866025.
    Hole Diameter = Nominal Major Diameter - 5/8 Pitch x Cosine 30 degrees
    Hole Diameter = 0.190 inch - 0.625 x 0.03125 inch x 0.866025
    Hole Diameter = 0.190 inch - 0.016915 inch
    Hole Diameter = 0.173 inch after rounding to 3 decimal places.
    Jan 2003
    Canada
    10,781
    4611
    2937
    I didn't read the whole thread but I've usually heard TDS for roll taps is right around pitch diameter. Usually best to try one in a piece of scrap first and see what the final ID is, it usually has a fairly open tolerance anyway.
  11. #11
    May 2005
    Napa, California
    1,040
    221
    99
  12. #12
    Mar 2005
    Connellsville PA
    560
    10
    Karl B.
    Here is a simple chart that has percentage of threads for cut and formed threads. This data is from several sources and is one of those long hair academic exercises; There is source material that was traced. This chart is updated and expanded about once a year to include the latest bastard and obsolete information.
    Hey; its free.................http://www.molineparts.com/images/36x96.pdf
    Break out the magnifying glass if you print it out normally. This chart is 24" by 70" in normal size. When it prints you can hear the ink being sucked down as the plotter grinds on.
  13. #13
    Sep 2005
    Missouri
    533
    17
    10
    For thread forming #10-32 holes in 6061 T-6 aluminum stock, I usually use a 0.177" drill (IIRC that's a #16). If your fit class is tight, I'd start in scrap with John Garner's info in post #9 and start out with a 0.173" (#17) and then check it against your gage.
    Gotta love them roll forming taps. It's been years since I broke a tiny tap.
