Not sure how to fix this, basically would like to clean up the area where the flax stuffing rides as it has some electrolysis corrosion, customer wanted me to weld it up and grind it down but I’m not interested in doing that and I don’t see a way of removing the shaft from the bronze spade, must be cast onto it ? Thinking of sleeving it either with a slip fit and JB weld or making a 3 inch long heat shrink with a collar like a speedisleeve. I am sure I could add 1/16 inch to the diameter and still get the packing in. Probably need to bore the ID for the fit and then turn it on an arbor for the OD. Or we could just JB the pitted area and stick it back in. I don’t see any way of removing this shaft so would need to build or buy two new rudders and I don’t think he is willing to do that at this time. Any ideas?
