Hello everyone.
Long time lurker first time poster because I need a little help, or perhaps just a second/third/fourth opinion.
Earlier this summer I got my hands on an old Victoria mill (sold under the name Elliot in the US). It's originally a horizontal mill with a universal table, but mine has been outfitted with a vertical head instead. It lacks some of the features of a dedicated vertical mill, but it will serve my purposes just fine.
Anyways, when I got it it needed some love and I've spent my free time during the summer restoring the machine. When I got it the spindle itself had some run-out and the morse taper in the spindle had some dings and scratches that made this worse.
So I removed and cleaned the spindle, the bearings and everything else, mounted the spindle in my lathe and very gently reamed the inside of it with a morse taper reamer, made some other minor changes so it would better be able to take a ER32 collet chuck, and finaly I turned a new drawbar on the lathe.
Once I remounted the spindle and remeasured the outside I was glad to see that all the run-out had been eliminated. I mounted the ER chuck and read the run-out on this. It gave me a little less than 0,02mm, so less than a thou, which I feel I can live with.
However when I mounted my 12mm milling bit in the chuck and took a reading of this it gave me almost 0,1mm worth of run-out. I was surprised and tried to unscrew the collet and remount the bit. After trying this a few times I managed to eliminate some, but by no means all of the run-out. The Best I can do seems to be about 0,05mm (roughly 2 thou) wich is still way too much.
Now, personally I suspect that the fault lies with the ER Chuck and collet set I bought, since this is the first mill I own myself, and since I knew it might need some work I didn't spring for a high quality set, but rather bough some cheap Ebay stuff. As far as I can tell the machine is running pretty straight so it seems to me that the fault would lie with the chuck/collets, but before I run of to buy a fancy new chuck and collet set I figured I could ask you guys here if there is something that I might be missing? Is there some variable in the machine that might be causing this, some part I should troubleshoot before I just try to throw money at the problem?
I should also mention that everything else about the machine seems near flawless, I runs like a dream, is strong and quiet, stable as all hell and both the bearings and gears seem to be in excellent condition.
