eng4turns
- Jan 21, 2008
- Kissimmee, Florida
Here's the backstory: I'm building a tool and cutter grinder for my home shop and have chosen to make one of the tool-holding arbors 5C, since my shop is set up around those and I've got a full set. I've made the arbor including the drawbar and it all fits and works nicely. Simulating the left end of my South Bend 13" lathe's spindle, I made a 45 degree taper on the back end of the arbor for a mating taper on the drawbar to engage with. I went to some lengths to ensure that the nose taper and back end taper were concentric within one thou.
The question: How important to the concentricity and repeatability of the 5C workholding collet is this "backend" of the assembly? It's pretty obvious that if you were off 10 or 20 thou between the 5C taper at the nose and drawbar taper at the other end of the arbor, then the collet could be forced into a skewed position. But what about a couple of thou difference? Will the nose taper overwhelm that offsetting force?
Ed in Florida
Ed in Florida
