Picked up a 14" vertical/horizontal Cal-hawk bandsaw in excellent shape. Tonight was the 2nd time using it. While I was cutting a piece of 16 gauge steel, the blade popped off. Nothing alarming. I reattached and turned the machine back on. It popped off again as soon as I turned the saw on. So I reattached it and tightened it a little more than the last time. Popped right off as soon as I turned it on again.
I'm more of a hobbyist than a professional and this machine is new for me, I don't know a whole lot outside of just using them. I noticed the top wheel has some play in it and the bottom wheel is nice and tight. The screws on the bracket that hold the top wheel in place are tight. I can slide the top wheel left to right on its shaft about 1/2" total with its bolts tight. If I tighten the bolts any further, it makes the wheel scrape against the adjusting mechanism that dials the wheel up to tighten up the blade. Is this normal?
I feel like it needs a shim or something to keep it away from the adjusting mechanism so it doesn't scrape. And why all of the sudden is my blade jumping off no matter if I make it just comfortably snug or tight? Thanks in advance for any advice!
