Background
I'm mostly a woodturner, on a budget, that turns as a hobby.
About 5 years ago I started buying antique machinery and storing it. That gave me access to much better quality machine, than I could normally afford.
Now, I have a nice collection of fully restored machines, mostly about 100 years old, all in use.
And, I'm feeling the need to upgrade by lathe.
I have done many large pieces (up to 500 lbs) but thats really pushing my machine to, and possibly beyond, the limit.
The Goal:
I'm sure this has come up before, and I've read a lot of online articles, seen YouTube videos and so forth. But I'm set on building a big bowl lathe, very similar to Ed Moulthrop seen here: The Moulthrop family of woodturners - YouTube
Requirements
Is to build a dedicated bowl lathe, for:
- large diameter (~32")
- rpms typically 200 - 1000
- heavy (~2-300 lbs) blanks of solid wood
- These will be off balance, so will be mounted to faceplates.
- able to run in reverse (so the faceplates will like have a cam lock solution (or similar)
- the whole thing as to withstand vibration of the piece being off-centre (no idea how to calculate these forces
- Power: I have 5 hp, 8 pole motor, plus matching VFD and DriveALL
Options
Large concrete base, a 1" thick steel sheet on top, with threaded rod, down into the concrete.
From the pics below, plan A, was to use plummers blocks and get the spindle custom made.
However...from reading through this post http://www.practicalmachinist.com/vb/archive/index.php/t-308682.html it seems that a used Setco spindle might be a better solution.
A bit of surfing got me to these guys:
Setco 43 9BY.2 951 C.W. From Rear Horizontal Sidewall 2-1/2" Shaft Box Spindle | Bullseye Industrial Sales
Setco does not have a lot of info on older models and I can't find much info.
These do appear to be for milling machines (or similar)
At $300, I can't get a custom job done for that price.
And this thing looks to be massively strong. And might be a much better solution
So my questions are
1 - at the cutting end, I would like to weld on a mounting plate. My faceplates will be screwed/bolted to the wood, then bolted to the mounting plate.
This plate on the Setco, is that a solidly mounted plate that I can bolt to?
2 - some of these grease lubricated, some oil. Seems like the oil ones need a constant flow?
3 - weight. This one is 9x10x21" which I calculate as ~500 lbs. Does that sound right?
Thanks for the feedback.
Olaf
The Goal:
Requirements
Options
So my questions are
Olaf
