Peter Colman
Stainless
- Sep 22, 2004
- Rugeley UK
I have to make 6ft lengths of Ali extrusion from solid flat bar. My mill has a 3ft table and 2ft stroke. My plan is to produce a jig about 8ft long with a series of clamps along it and fix it to the miller table.
This would support the bar and help stop it distorting during machining
I would take one cut and then wind back, move the bar back to the cutter, clamp and mill again.
Before we go any further, the alternatives have been well covered by my customer, the extrusion is discontinued, a new die will be 12weeks, minimum order is vast. We need only 15 legths and have 5 weeks to deliver the finished fabrication.
The problem is how to true the jig to the miller. I know how to clock it up by setting a DTI on the column and wind the table back and forth but my machine has a universal table that can be swung about 30 degrees left and right, I don't think this a problem in this application, just set the scale to zero and true as above.
Am I right in thinking this, if not how do I set the table true?
Also, in 50 years at this game I have never needed the table to be anything other but 'normal' so what is this feature for?
Remember, there is no fool like an old fool, thanks for your time in reading this and all help is appreciated as always.
Peter
Peter
