Hi,
I have this drawing of a shaft with key slot (see the attachment). The drawing has both symmetry and parallelism tolerances controlling the key slot orientation. I understand the point of symmetry tolerance in the given situation (or leat I think I do) but what I don`t understand is, why there is also the parallelism tolerance stated.
I also made a schematic of the interpretation of the given symmetry tolerance as I see it (see attachment 2).
As I understand, base A is the centerplane (green) of the shaft which is perpendicuar to the nominal (theoretically exact) key slot "floor". It is the centerplane and not axis, because the corresponding dimension does not have diameter symbol in front of the value. The symmetry tolerance zone is bordered by two planes (magenta) which are ideally parallel to the shaft centerplane and 0,08 mm apart (drawing is metric). The symmetry requirement states that the centerplane of the key slot (blue, derived from slot walls) has to locate inside the given tolerance zone.
So my question: What is the meaning of the parallelism tolerance? Symmetry already states that the key slot has to be parallel to the shaft axis (shaft centerplane)...
All opinions are welcome!
