Shaper 415v - 240v
Community On The Web
Results 1 to 6 of 6
    May 2017
    AFGHANISTAN
    15
    Default Shaper 415v - 240v
    I recently purchased a 16" demco excelsior shaper and has a 1.5kw/2hp 415V electric motor on it.
    Am I better off simply swapping to a 240v motor or is it possible to use a VFD (don't know much about them). I'm in Australia if that makes much of a difference
    Thanks for the help
    Apr 2005
    powell river bc Canada
    696
    28
    110
    easiest to swap motor if 415 volts not available.
    A vfd will not change the voltage.A transformer would.
    Sep 2007
    Cairns, Qld, Australia
    2,460
    597
    524
    If you can rewire the motor from star 415V configuration to 240V delta you'll be able to run it off 240V single phase with an inverter drive.
    May 2017
    AFGHANISTAN
    15
    Changing from star to delta would you loose HP? I thought I read it halves the power, I may be wrong and miss read it.
    So swapping out the motor looks to be the simplest, however it has a electrical box on the side (see photo) do I just disconnect power completely to the box and just wire the 240v to a new on/off switch?
    Mar 2012
    Geilenkirchen, Germany
    1,513
    1013
    729
    I'm afraid your desire will be a bit more complicated. I see a transformer in the control box. This feeds something. These machines were designed to use a 4 wire service without neutral. These transformers will create a local low voltage supply that would feed control relays and/or a machine lamp. You must check it out before you do anything. I suspect your knowledge may not be up to it. If so, ask an electrician.
    Sep 2007
    2,460
    597
    524
    Quote Originally Posted by jlmtb1 View Post
    It won't lose any power at all it just changes the voltage it runs on. Open up the motor terminal box if it has one and take a look at the terminals, most relatively modern motors have a range of voltages they can be configured to. It would be of benefit to find someone with some previous experience doing this sort of stuff. If you run a modern VFD you'll be disconnecting most of the contents of that electrical box and running power to the VFD unit direct.
