I finally got my Bridgeport. Phase 1 was getting it from the ship point into my garage. The head was removed to fit it in the delivery truck. It is on a skid. That part worked out well and is complete.
I have a buddy coming over Saturday with his Bobcat to get it off the trailer and into the garage. That shouldn't be a problem.
Now for the fun. I can move the head off the table using my 2 ton crane. He can put it into position with the Bobcat. The only problem is that it will still be on the skid. In order to get the skid out from under it, I need to lift it a few inches. My question is: Can I run a chain through the mounting bracket inside the column (is that the right term?) and lift it using that? This is the same bracket that holds the head on, so i'm guessing it will be strong enough. However, I thought it would be a good idea to ask before i cracked it and put myself behind in setting it up.
Caspian
Caspian
