Sharpening carbide drill on diamond wheel?
Results 1 to 14 of 14
    Dec 2006
    Naples, FL
    203
    Default Sharpening carbide drill on diamond wheel?
    I want to sharpen some carbide drills. I know the green wheels work but I was wondering how a diamond wheel works on carbide? Specifically, I would like to use my Drill Doctor which has a diamond wheel. I realize it's not the best or most precision way to go but it would be better than I would do by hand on the green wheel.
    Vern
    Jan 2005
    The Netherlands
    5,301
    219
    1207
    Quote Originally Posted by Vern Smith View Post
    Vern
    I know the green wheels don`t work
    You grind carbide with diamond, at least if you want it sharp
    With those green wheels it is practicly impossible to get a sharp edge
    On the other hand if your drill doctor is meant for HSS drills it probably is a CBN wheel and not diamant
    Peter from Holland
    Feb 2006
    Indiana
    11,969
    446
    3145
    Green silicon carbide grinding wheels are able to remove excess tungsten carbide, as when you have a broken tool and need to grind back a bunch of material before resharpening. They are of no use at all for sharpening carbide, which is done with diamond.
    As for the forbidden (it is on Millie's little list) DD machine, you are free to try it, or to inquire of the maker for advice.
    Larry
    Jul 2007
    UNITED KINGDOM
    4,279
    2006
    1800
    On their website, they claim the wheels are diamond (no reason why not, CBN would not be an advantage for this use) and that carbide bits are amongst those than can be sharpened.
    Sep 2004
    Sonora , Calif
    549
    109
    112
    Default green wheels
    I worked in a production machine shop for about 20 years before the shop got a diamond wheel
    and we sharpened carbide tools with green wheels every day.
    Jim
    Jan 2010
    Kansas City
    2,788
    1252
    1798
    Vern
    If you can dress the green wheel with a diamond dresser and get it SMOOTH, you just may have a chance. Not a good one, but a chance.
    Your best bet is to find a good diamond wheel, around 100 grit. Mount it up, indicate and shim it true. This will get you MUCH farther, faster.
    DON'T use the drill Dr. You will do nothing but ruin the CBN wheel inside.
    Feb 2002
    Peralta, NM USA
    5,413
    39
    320
    Quote Originally Posted by smalltime View Post
    Their manual says that you can, and I've sharpened a couple dozen carbide bits in my old 750 with no apparent damage to the CBN wheel. But maybe I have to do a few hundred before the damage shows up or something.
    Jan 2002
    West Coast, USA
    7,269
    352
    4179
    The original DD -- at least the one I keep around for left hand bits -- has a diamond plated wheel, not CBN.
    Jun 2007
    New Zealand
    2,661
    28
    I'm perplexed by the oft repeated notion that green grit wheels are no use for sharpening carbide.
    They not as good as diamond wheels. Does that make them "of no use"?
    I don't bother setting up a diamond wheel to sharpen, say, a brazed carbide lathe tool for roughing interrupted cuts hard material. Or for (as I often do) modifying a masonry drill for hard metal drilling.
    Green grit is just FINE for jobs like this, and preferable to diamond IMHO in cases where the steel substrate will contact the grinding wheel (and consequently greatly reduce the life of any diamond wheel not specifically targetted towards steel grinding: slow speed, coolant....)
    It's a bit like saying manual machine tools are "of no use" since the advent of CNC.
    There was a time, thanks presumably to the genius of de Beers, where diamond wheels (at least in the semi third world conditions of our local industry) were pretty much something you read about rather than owned, the Lamborghini Miura to our Lotus Sevens and Mini Cooper Ss.
    I'm talking about during the carbide era (I'm old, but not exactly a centenarian)
    ... the lucky few would tickle up the resulting edge with a pocket diamond hone (even these used to cost a prince's ransom) and be away laughing. The rest of us would be perfectly satisfied with the off-stone finish.
    (Chorus from offstage: Looxury! You 'ad a green grit wheel? We had to roob tools on concrete path wit' bare 'ands!)
    Jun 2001
    St Louis
    16,777
    1391
    2565
    The issue with green wheels is that they allegedly tend to fracture the edge and lead to premature dulling, rather rapidly.
    Having used diamond wheel and green wheel, both, I am tending to believe there is a definite difference. WHAT the difference is, I don't know of my own personally developed knowledge.
    For sure, a carbide scraper sharpened with diamond wheel will last WAY longer in scraping than a green wheel sharpened scraper.
    You-all can do as you like on that score.
  11. #11
    Mar 2005
    Northwest Indiana
    3,353
    335
    431
    Green wheels are crap for grinding carbide. There. I said it. The green wheels do not cut the carbide so much as chisel it off. Every time I use a green wheel to rough carbide tools I can see the fractured edge. Check it with a loupe if you can't see it with your naked eye, it's there. This has a major affect on tool life.
  12. #12
    Jan 2008
    Vitoria Brazil
    12
    Diamond works much better.
    However, if you want the diamond to last and do a good job, YOU MUST LUBRICATE THE WHEEL WHILE GRINDING!! either with water or oil.
    Oil makes a mess. Water works just fine. Without lube, your diamond will "burn" and not last as long. Also, I don't think you will get as good an edge.
  13. #13
    Nov 2004
    Birmingham, AL
    12,999
    6060
    2400
    Green wheels are fine for shaping carbide. Use Diamond for final sharpening, grinding fine radiuses and chipbreakers. Sharpening carbide with a green wheel works if there is no other choice, but it's like sharpening your pocketknife on the sidewalk.
  14. #14
    Jun 2007
    New Zealand
    2,661
    28
    Mike
    thanks, I think that's a helpful analogy
