Sheldon R15 Is Home
Results 1 to 20 of 20
    Dec 2007
    N.E. oHIo, USA
    2,358
    1368
    Default Sheldon R15 Is Home
    The move was a little tense due to wanting to get the 6X10 hydraulic lift bed trailer back to Sunbelt Rental before they closed at Noon, but we got it handled without major issues.
    Ray Behner's skates are the cat's ass, although I would have cut some 2X4 blocks to keep the lathe centered in the skate had I been thinking.
    Other than some cosmetic issues from sitting in an unheated NE oHIo garage for the past 5 or so years, things look to be in good order. Head cover will be coming off later today to check gear train, and the quick change gearbox and the apron innnards look good inspected through the fill plug holes. Previous owner was a tool and die man for Ford Motor Co., and by the looks of things he was diligent with his maintenance.
    The Sheldon should be a significant upgrade from my 10X30 Atlas.
    Rex
    Mar 2009
    Brunswick Oh USA
    4,256
    4294
    2495
    Rex,
    Well, it's about damn time we heard from you. That's a good lookin' South B......er Sheldon. Glad the skates worked.
    Rats, I was gonna tell you I clamp chunks of wood to the skates.
    Nov 2004
    Webster Groves, MO
    6,245
    1500
    2523
    You may be forgiven once, but only once. It is a mortal sin to say "Sheldon" and that other lathe in the same sentence. The only thing they have in common is a spindle that turns. I have an R15 that came without the motor and gearbox. I installed a 15 hp DC motor and a variable power supply so I have any speed I want. Sheldons are superb lathes. The cross slide design avoids the common problem of chips falling on the left dovetail accelerating wear and has a huge slide area, so wear is minimized. The only downside is that you have to keep walking around the protruding slide and crank, but it is a small price for the advantages. The threading gearbox must have cost more to make than most lathes. One thing to watch for, though, is the wide deck on the cross slide which makes it too easy to run it into the chuck. You really have to watch it. You will love it.
    Bill
    Mar 2009
    Brunswick Oh USA
    4,256
    4294
    2495
    Bill,
    I beg your forgiveness. I lost my mind for a moment! Yes, they are superb machines. As for the cross slide sticking out, you're right. But you get used to it in a hurry. I just suck in my belly automatically. Yup, that gearbox is a hoot. I had mine in every piece she'd come in. It even has timing holes for disassembly and assy. Boy, the needle rollers and thrust bearings. They're everywhere! I don't think Rex could have done better. It becomes second nature using the drop outs on long and cross feed, but until you have it you haven't a clue how handy it is.
    I'll try to behave from now on.
    Ray
    Dec 2007
    N.E. oHIo, USA
    2,358
    1368
    Default More R15 Pics
    Got the headstock cover pulled off and found all of the gearing to be well lubricated, all teeth intact and no sparkly stuff floating around. There ain't much going on in there compared to pics of other machines I've seen.
    I mounted the 4 way tool post....seems to be a pretty stout unit. According to the scale attached to the base it indexes in 3* increments. Scale is stamped "OK RUBBER, INC. Littleton, Colo." and "French Pat. Pend." Anyone know anything about the company? Nada on Google.
    Rex
    May 2011
    southern in.
    1,282
    1692
    331
    Hey Bjorn : Your pics are very interesting. Construction wise, it looks very much like my 15" South Bend Nordic, which was made in France. I wonder if they are half-brothers or cousins or something like that. Do you know anything about where it was made ?
    JH
    Dec 2007
    N.E. oHIo, USA
    2,358
    1368
    James, the Sheldon was made in the U.S. of A.
    Rex
    Jul 2010
    Stillwater, MN
    57
    7
    Had one of these in the engineering lab at school. Boy do I miss that lathe!
    Nov 2004
    Webster Groves, MO
    6,245
    1500
    2523
    Incidentally, now that you have a real lathe, do you know that you can fasten a coffee can to the faceplate on your Atlas and it will make a terrific rock tumbler?
    Bil
  10. Likes thermite liked this post
  11. #10
    Oct 2005
    9,880
    17024
    5085
    Bjorn,
    is that the lathe featured in the cleveland Craigslist ?
    I have it's brother, only a longer bed. Mine is missing the gear on the bottom
    of the thread dial, if you get around to it, could you measure it up for me ?
  12. #11
    Mar 2009
    Brunswick Oh USA
    4,256
    4294
    2495
    Rex,
    Hey, when I come up for a look see, you'd better have that toolpost fastened tight. It may disappear! The lack of all the gear changes in the headstock is what Sheldon touted for achieving a smoother finish on the workpiece. The changes were before the belt in the transmission. May not be of the 10-EE Monarch ilk but a damn close second.
  13. #12
    18,891
    7561
    5971
    Quote Originally Posted by 9100 View Post
    Bil
    Helps if you put a cinder-block under the bed at TS end to tilt it...
    Bill
  14. #13
    Mar 2009
    Brunswick Oh USA
    4,256
    4294
    2495
    Doug,
    I had to make one of those for my 13". They're all the same gear. It measures: 1.307 OD x 26DP x 14½PA x 32T. OAL of gear is .688 w/.450 gear width. Remaining length necked down to .990. It was made of some sort of phenolic material. I used (I think) garolite. The teeth are angled about 2º to mesh with the angle of the leadscrew. This material must have been for a shear factor, but aluminum would probably work. It can be removed and stored in the right side of the apron. 'Least mine can.
  15. #14
    Apr 2006
    Manchester, England
    6,980
    865
    3949
    Looks a nice lathe. I especially like the serrated ring under the toolpost, I've never seen that before on any other lathe. Regards Tyrone.
  16. #15
    Dec 2007
    N.E. oHIo, USA
    2,358
    1368
    Bil
    Bill, that's harsh!
    Over the years my lil' Atlas has made many times its weight in chips.
    Now, I can look forward to making lotsa blue chips!
    Rex
  17. #16
    18,891
    7561
    5971
    Quote Originally Posted by bjorn toulouse View Post
    Bill, that's harsh!
    Rex
    My M6 hasn't run more than mebbe a hundred hours in bedroom, kitchen, bathroom, and finally a proper shop since bought new in '68. But it has paid for itself several times over in the 'emergency' parts made for the oddball cars or firearms I've been wont to play with alone.
    Defiant little beast is still giving the finger to the 10EE 'coz it has power and tooling the 10EE hast not.
    Perhaps in the next year, I'll try to find it a good home. It has certainly earned that much ... vs a hacksaw blade or coffee-can on its nose.
    Bill
  18. #17
    Nov 2004
    Webster Groves, MO
    6,245
    1500
    2523
    Bill, that's harsh!
    Rex
    Perhaps so. I realize that some people can do good work with these machines, for that matter, a good craftsman can do creditable work with a sharp rock, but I have a bad attitude toward entry level equipment of the sort that must not be named here. Like most attitudes, a result of my formative experiences. I struggled with a couple of 9" Logans, a light 10 South Bend, all on wood benches, and spent a lot of the time learning bad habits. I especially remember trying to make a cut off tool work in a lantern toolpost on a Logan. Today I was cutting off a bunch of 4 1/2" dia pieces of 6061 T6 on the Sheldon with a 1/8" blade on an Aloris toolpost. Just run the speed up to 700 RPM with the gearbox on E10, make sure the cutting oil is going in the slot, engage the feed and watch the chips fly.
    Our Sheldons are medium duty machines, not in the same class as the big Monarchs, DS&Gs and American Pacemakers, but unless you are doing really heavy work, they are great.
    A beginner doesn't need a top quality toolroom lathe, but neither should he be unnecessarily handicapped. If I was to set out to teach someone to run a lathe, the lowest I would want to go would be the smaller Clausings.
    Bill
  19. Likes Ray Behner, digger doug liked this post
  20. #18
    18,891
    7561
    5971
    .. or a dull one, even. Impact or abrasion being often as useful as shearing.
    One uses what is at hand...
    Bill
  21. #19
    Aug 2008
    northeast USA
    87
    19
    nice machine.... how did the trailer work out?
  22. #20
    Dec 2007
    N.E. oHIo, USA
    2,358
    1368
    The trailer worked great!
    Too bad they're so pricy, I'd like to own one.
    Rex
