I'm working on a project and I just realized that I will need to weld 2 steel plates together. I thought it was possible to get away with bolts and nuts, but thats not the case for me.
The steel absolutely needs to be hardened. The problem is that after welding the two hardened pieces of steel, there will be a heat affected zone with lower hardness.
I was thinking about first welding them together, normalizing 3 times and then hardening+tempering. But wouldn't it stress the weld and make it weak somehow?
I'm very inexperienced with welding, in fact I started 2 weeks ago.
The steel alloy used is 5160, 1/4" thick. The electrodes are 7018 2,5 mm thick, because I found it much easier to start the arc with the thinner ones.
