silicone gasket for gas can
Results 1 to 10 of 10
    Apr 2004
    Modesto, CA USA
    5,642
    820
    Default silicone gasket for gas can
    I need to make a simple gas can gasket. I have some sheet silicone, no idea where it came from, may even be from bake ware. I understand that silicone is vapor perimiable. how will it work for gasoline. Will it allow the gas to go stale too fast. Other choice I have on hand is cork gasket sheet. No idea how that will work with new improved? fuels.
    Yes I know I should buy the right stuff but this a holiday weekend and I just want to make sure the silicone will not disolve.
    Bil lD.
    Nov 2007
    marysville ohio
    8,626
    2444
    5469
    Use the cork, silicone will probably swell.
  3. Likes baldwin liked this post
    Jul 2007
    Willamette Valley, Oregon, USA
    419
    112
    99
    Moonlight machine is right--silicone will not be suitable. To determine material compatibility you can consult the many chemical resistance charts which are readily available on the web.
    -Jeff
    18,244
    7561
    5730
    Quote Originally Posted by Bill D View Post
    Bil lD.
    For a holiday weekend, paper - as in cardboard cut from a school-tablet back - will work better and last longer. There can be over a dozen different chemicals in pump gasoline, not all of them friendly to the components of silicon-rubber. Unless you have a stash of the variious sheet-goods and sealants specifically intended for fuel systems, anyway.
    Next hint would be that El Cheapo plastic gas cans use plastic directly for containers, spouts, cap, and sealiing disc.
    WHICH of the 40 brazillion available plastics?
    Pass.
    But the likely suspects include polypropylenes and polyethylenes, including the polyethylene terepthalate (PET) of recyclable food and drink containers.
    Multiple possible hazards of gasoline as they are, 'most wiser' to get a 'proper' cap and gasket at first opportunity. They are sold separately, and generally cheaply enough it ain't worth the bother of DIY for the one gasket as goes missing or damaged every fifteen years or so.
    Bill
    Dec 2009
    South Yorkshire, England.
    367
    551
    28
    In the UK the typical 5 litre petrol or gas can is made wholly of plastic - the thread area has a tapered end section to make a seal in the cap, thus there is no gasket to lose.
    This is the sort of thing I mean Halfords | Halfords Green Plastic Petrol Can 5L
    Steve
    Dec 2004
    uk
    12,418
    3432
    5541
    Inner tube will work just fine as a petrol gasket short term with the uk std unleaded fuel. it swells a bit but does not break down - dissolve.
    Sep 2006
    SE PA, Philly
    5,125
    923
    1592
    Geez, guys, they DO have compilations of solvent compatibility. The one here states that normal silicone has poor resistance to gasoline. Fluorosilicone is supposed to be pretty good, but that's probably not what you've got.
    If the cork sheet is a cork/buna-N composite, it should work great. Test your cork material: put a little bit of gas in an old jelly jar and submerge a bit of cork material. Cover. Check after a few hours to see if it crumbled or swelled. If not, go for it.
  9. #8
    Apr 2004
    Modesto, CA USA
    5,642
    820
    this is for a standard jerry can. It may be a California thing but they no longer carry the standard screw on spouts for gas cans here. This means they no longer carry the simple flat gasket either. A few places left to try after the holiday.
    Bill D.
  10. #9
    18,244
    7561
    5730
    Bill D.
    I'd suggest confirming it is wot it is here:
    http://www.google.com/search?q=jerry...w=1209&bih=867
    Use of a scissors-cut carboard one for a week, whilst ordering online - with spares - from the likes of:
    Jerry Cans and Accessories : Jerry Can Gaskets (10-pack)
    Jerry Can Gaskets - Military Parts
    If you make anything 'nicer' than cardboard, you will be tempted to just live with it indefinitely. Which may not be as safe...
    Bill
  11. #10
    Jun 2012
    Minnesota, USA
    1,877
    356
    674
    If you're talking about an old military gas can, I tried a silicone gasket years ago. It sealed well enough, but it was too soft, and it couldn't handle the twisting that was part of closing the cap. Gaskets are available on-line from military surplus dealers, but if you buy any, be sure they are still soft. Gaskets get harder as they age, and they won't seal worth a hoot.
    Short term might be some cork or fiber gasket material. I've cut similar gaskets using a chunk of plywood chucked up, and then staple the material to the plywood, making sure that the staples are outside the gasket area. Grind a lathe bit into a knife shape, and cut the center out, then cut the outer diameter. Don't try to use an Xacto-knife blade or a utility knife blade - they don't survive for very long.
    Military gas cans normally need a tool to tighten - the standard 18" long heavy-duty screwdriver works well.
    FYI: In WWII, there was a shortage of tankers (due to German submarines), and the military had a hard time shipping gasoline to Europe. Since the military also needed gas cans, some genius got the idea to ship filled gas cans by liberty ship. The cans never seem to seal 100% - about 98% is about as good as it ever gets. The end result was that they had an entire ship full of 5-gallon cans, with every one of them leaking just a little bit as the ship rolled and tossed. One captain reported that the ship's bilge pumps were always pumping gas along with normal bilge water, and that the "smoking room" was a lifeboat that was towed behind the ship. Also remember that Liberty ships were steam powered. Sounds like an interesting way to make a living....
